Had my 2001 AMK, (111K) in for the MOT today and it has failed on emissions, don't have the print out sadly but the chap said it failed on all 3 tests and was well off the limits.
Car is running a Pipewerx 3" system with a sports cat that is 18 months old, a new Bosch post cat lambda was fitted at the same time.
Car runs and drives fine, haven't noticed any performance drop or any increase in fuel consumption, no active faults on VCDS.
Any hints on what I should be looking for? I'm sure it is a sensor or something causing it to run rich as it went through no problem last year with the same cat setup and I can't believe it has failed that quickly, from what I have read even without a cat they should be pretty close to the pass limit.
I've seen posts suggesting the temp sensor can cause rich running? I'm not a fan of throwing new parts on without a decent indication of what the source of the problem is but emissions have always been a bit of a mystery to me!
Any help much appreciated!
