hi, im getting this fault , once i delete it it comes back after a few days, drives fine , no loss of power , starts perfectly.
i did remove the sensor , cleaned it but the eml comes back on after about a week
5120-lambda sensor B1 S1
2196-00(237) signal too (rich)
mil on confirmed
fault status 00000001
fault priority 2
fault frequency 1
i have deleted the fault 2 days ago here is the scan below
Code:
Sunday,30,July,2023,14:57:25:22644
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WAUZZZ8U6ER044674 License Plate:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 22 25 42 44 46 52 53 55 5F 62 72
VIN: WAUZZZ8U6ER044674 Mileage: 157570km-97909miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFFB) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 CM HW: 03L 906 018 ES
Component: R4 2.0l TDI H28 9977
Revision: 41H28--- Serial number: CVN: E90C9A75
Coding: 00190012043701080000
Shop #: WSC 00780 002 1048576
ASAM Dataset: EV_ECM20TDI01103L906018CM 003005
ROD: EV_ECM20TDI01103L906018CM.rod
VCID: 77ABE927EF48C3F23E1-8022
VINID: 9D196AAAA22519588010418710726693E9
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 AT HW: 5N0 614 109 AT
Component: J104 C6 450M VD72 0150
Revision: --H07--- Serial number: 00000007490197
Coding: 0056711
Shop #: WSC 00049 770 00156
VCID: 7DA7FB0FC1F4E9A264D-8028
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8U0 820 043 D HW: 8U0 820 043 D
Component: E87 Klimavoll 0100
Revision: 00H04000 Serial number: 8U0820043D
Shop #: WSC 00000 000 00000
VCID: 323D1833482AE6DAC9F-8066
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 N HW: 8X0 907 063 N
Component: BCM PQ35 M 112 0771
Revision: AG112771
Coding: 0E000A2CA807F1C0201841C021000D4C53FF84AA216F912BE408878400C5
Shop #: WSC 00049 770 00008
VCID: 47CB59E7DFA873728E1-8012
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 131001 H36 0085
Serial number: 131003114119
Coding: 0047F7
Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0002
Serial number: 21840414
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177
Component: DWA-Sensor H0 H01 0020
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Address 10: Park/Steer Assist (J446) Labels:| 8X0-919-475.clb
Part No SW: 8X0 919 475 N HW: 4H0 919 475 AG
Component: PARKHILFE 8K H01 0050
Revision: 11001001 Serial number: 61061328401175
Coding: 08C205
Shop #: WSC 00049 770 00119
ASAM Dataset: EV_EPHVA18AU21X0000 003006
ROD: EV_EPHVA18AU21X0000_003.rod
VCID: 51FF77BF216CBDC2D05-8004
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 B HW: 8U0 959 655 B
Component: AirbagVW-AU10 H08 0520
Serial number: 003LRR06LFWN Dataset Number: 8U0909602A 0009
Coding: 30393132313030303030554A305238553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001005
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 46D554E3D8226A7A757-8012
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.V H02 ----
Serial number: 3496KSME55753F29ZZZ4
Front Passenger's Side Airbag Crash Sensor:
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.V H02 ----
Serial number: 3506KSME31172629ZZZJ
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Fahr.H H02 ----
Serial number: 3516KSME2F561D29ZZZ%
Passenger side rear thorax airbag crash sensor:
Subsystem 4 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Component: S.Sens.Beif.H H02 ----
Serial number: 3526KSME592D2629ZZZ
Crash sensor for front airbag: driver side:
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Component: F.Sens.Fahr H02 ----
Serial number: 3555USME52703226ZZZT
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 D HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010018 Serial number: 20131106301207
Coding: 1084204000
ASAM Dataset: EV_SMLSNGVOLWSXS A01004
ROD: EV_SMLSNGVOLWS.rod
VCID: 3D273B0F8DF429A224D-8068
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 8U0 951 528 G HW: 8U0 951 528 G
Component: E221 - MFL H08 0010
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 980 E HW: 8U0 920 980 E
Component: KOMBI_MEDIUM H01 0330
Serial number: 00000000000000
Coding: 42CF01
ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
ROD: EV_Kombi_UDS_VDD_AU10.rod
VCID: 3E253C0380F232BA3D7-806A
Address 19: CAN Gateway (J533) Labels: 8X0-907-468.clb
Part No SW: 8U0 907 468 Q HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0063
Revision: 1P120037 Serial number: 3741P13A110B80
Coding: FBCF1A5A000100610353
VCID: 50F972BB2AE6B4CADFB-8004
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 30289J04341491273416
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 13290001793021200181
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 F HW: 0AY 907 554 F
Component: Haldex4Motion H52 7521
Serial number: HA1-00025.09.13 Dataset Number: v1260x015G0 0000
Coding: 0001
ASAM Dataset: EV_AllWheelContrHA1VW37X 002001
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 4EC56CC33052A23ACD7-801A
1 Fault Found:
16671 - Pump for Haldex Clutch
C1112 04 [009] - Internal System Fault
[Pump Motor - mechanisch defekt (mechanisch festgefahren)]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 114
Mileage: 157574 km
Date: 2023.07.30
Time: 14:51:33
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Component: IMMO H01 0330
Serial number:
Coding: 000002
ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H10 0415
Revision: -------- Serial number: --------------
Coding: 011E06200001000000
VCID: 52FD78B324EAC6DAE9F-8006
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 296 3501
Revision: 00H22000
VCID: 40D942FBF686444A4FB-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H10 0415
VCID: 51FF77BF21ECBDC2D05-8004
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000001533812
Coding: 0025166
VCID: 36352423A442FAFAE57-8062
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 8X0 907 357 C HW: 8X0 907 357 B
Component: ****LWR12**** H02 0020
Serial number: 131023-0002-107
Coding: 1157A41010002500
ASAM Dataset: EV_HeadlRegulBasic 005001
ROD: EV_HeadlRegulBasic_AU21.rod
VCID: 42DD48F3F40A565A59F-8016
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8U0 035 193 C HW: 8U0 035 193 A
Component: RMC Cnct Nav H54 0801
Coding: 0101060002C153070823020103010000000000
VCID: 3537232FB544F1E2ECD-8060
Subsystem 1 - Part No: 8X0 919 884 F
Component: P23-50-13.06 0001
Subsystem 2 - Part No SW: 8U0 919 603 HW: 8U0 919 603
Component: DUBasic AU316 H41 0018
Serial number: AUZ8ZDD0604MJ7U
Address 62: Door, Rear Left (J388) Labels:. 8X0-959-795.clb
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H07 0415
Coding: 010E06200001000000
VCID: 4FFB71C737D8AB32C61-801A
Address 72: Door, Rear Right (J389) Labels:. 8X0-959-795.clb
Component: TSG HR H07 0415
End----------(Elapsed Time: 01:23, VBatt start/end: 14.5V/14.4V)-----------
13 minutes ago#2
V
Verified
BELOW TAKEN AT IDLE
EGR SPECIFIED VALUE 83.9% at idle once i pressed on the throttle otherwise it was 0%
EGR SOLEN VAL ACTUAL VALUE 16.22%
EXHAUST MASS FLOW OF EGR 19.3 KG/H
INJECTION QUANTITY DEVIATION CYLINDER 1 -0.03 MG/STROKE
CYLINDER 2 0.14 MG/STROKE
CYLINDER 3 0.12 MG/STROKE
CYLINDER 4 -0.23 MG/STROKE
VOLTAGE OF OXYGEN SENSOR BANK 1 SENSOR 1 0.129 LAMBDA/0.597V
02 SENSOR 1BANK 1 ADJUSTED OYGEN VALUE 0.00000
OXYGEN SENSOR 1 BANK 1 RI CALIBRATION VALUE 10.7OHM
OXYGEN SENSOR 1 BANK 1 LAMBDA ACTUAL VALUE 2.105
OXYGEN SENSOR 1 BANK 1 STATUS CALIBRATION 0
OXYGEN SENSOR 1 BANK 1 VOLTAGE RAW VALUE 596.8MV
OXYGEN SENSOR 1 BANK 1 VOLTAGE VALUE 1003.0MV
mil on confirmed
fault priority 2
fault frequency 1
Code:
www.Ross-Tech.com
Coding: 0056711
Revision: AG112771
Coding: 0047F7
Coding: 02006E
Coding: 08C205
Coding: 1084204000
Coding: 42CF01
Coding: 0001
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 114
Mileage: 157574 km
Date: 2023.07.30
Time: 14:51:33
Serial number:
Coding: 000002
Revision: 00H22000
Coding: 0025166
13 minutes ago#2
V
vw754
Verified VCDS User
Verified
BELOW TAKEN AT IDLE
