Fuppylodders
Hi,
I'm looking to replace my turbo. It's always had an oil leak ever since I had the car.
It's a 2007 170 tdi Brd quattro. When I first bought it, I had the oil pump hex key replaced with the longer version.
It also had an oil leak at the oil feed pipe into the top of the turbo due to what looked like an incorrect washer. Looks like someone had been at the turbo before.
The prior owner also had gutted the dpf, blocked off egr, dpf sensor plug cut off, all the usual stuff for those extra few hps but mot regs back in 2020 changed that and I had to fork out to get that all sorted.
Anyway. After all sorts of various issues (throttle body, timing apparantly being out 1 tooth, TPS failing twice, reversing light switch failing...) I'm currently having another issue. On the odd occasion it idles fine. But if I let it tick over in gear, it has a very rough idle and seems like its hunting, and can also puff out a bit of bluey white smoke. But when I put my foot down to go, it is fine up to 2.5k revs then almost loses any further boost pressure and climbs up the revs like it has no turbo. I managed to remove the injectors, sent them off to be cleaned and flow tested, came back good and put them back in. Set their pump time and it feels more pokey but the flat spot/lack of boost/rough idling is still there.
I'm half thinking it's the turbo on its way out. I'm now also thinking perhaps the inlet pipe from turbo to intercooler might potentially have a leak. Am also wondering if that would cause the rough idle or is that likely the turbo going?
Given its got oil clearly leaking from the turbo, I'm ready to swap it with a replacement (remanufacture-however different that is from refurbed...).
First question is, I'm confused which turbo it's actually meant to have. I thought it was meant to have the one where the exhaust manifold is cast onto the turbo? Except, Ive been sent one that has no exhaust manifold cast onto it. Also, I'm finding lots of pics of the non manifold version when searching for my car info...
Anyone able to shed some light on that?
Also, is there a write up describing how to replace a turbo? I've seen some light info on it, that it can be done on some small ramps (it'll still suck not being on a lift) and that the subframe doesn't have to be dropped-just undo and twist the dpf up or something...
Also, is there anything I need to set up once I've installed it? And should I be replacing anything else while I'm at it? I think I read somewhere to replace the oil feed line...
I'm sorry my post may seem random in its structure... I'm kinda not great at that...
Thanks in advance!
Thanks in advance!
