Hi everyone
Just recently my engine feels like it is miss firing when the throttle is held steady at a constant speed.
It doesn't happen all of the time and there are no warning lights on the dashboard.
It has done it occasionally when parked up without moving.
I've scanned it with VCDS and it appears I do have an intermittent issue with stuck swirl flaps, see below:
There is no power loss under full acceleration.
The engine and gearbox has been remapped by Unicorn motor developments a couple of years ago.
Does anyone have any previous experience with the same issue or any ideas please ?
Is there a fix with the swirl flap fault that anyone can help with ?
Thanks in advance.
Address 01: Engine (J623-CGQB) Labels: Redir Fail!
Part No SW: 4G0 907 589 G HW: 4G0 907 589
Component: 3.0BTD EDC17 X25 0003
Revision: 57X25--- CVN: 937757B3
Coding: 0A2A4032252603020000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM30BTD0114G0907589G 001003
ROD: EV_ECM30BTD0114G0907589G.rod
VCID: 3879446183FAEE513B-806C
VINID: 9D196AAAA11711578114414614A5BAF740
1 Fault Found:
9130 - Intake Manifold Flap; Bank 1
P2004 00 [01100000] - Stuck Open
Intermittent - Not Confirmed - Tested Since Memory Clear
Thanks in advance.
1 Fault Found:
