trailer manoeuvre assist activating
Adrian1871
Age
is it possible too activate trailer manoeuvre assist with my new hex2 lead ? hi have 360 degree cameras and parking plus?
Sunday,24,March,2024,16:46:02:33420
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 23.11.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20231027 DS351.0
www.Ross-Tech.com
VIN: WAUZZZF28KN016685 License Plate: X31ADA
Mileage: 72531km-45068mi Repair Order:
Chassis Type: F2-AU58 (4N2)
Scan: 01 02 03 09 13 15 16 17 19 1B 2B 36 3C 42 44 46 47 52 5F 61
69 6D 74 81 82 A5 AC BB BC C4 CA CB CC CD CF D6 D7 DB DC DD
DE
VIN: WAUZZZF28KN016685 Mileage: 72531km-45068miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
74-Chassis Control -- Status: OK 0000
81-Gear Shift -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
AC-Reductant Control -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
C4-DC/DC Converter -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CB-Rear Axle Steering -- Status: OK 0000
CC-Starter-Generator -- Status: OK 0000
CD-Laser Scanner -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
DB-Frt Corner Rdar 1 -- Status: OK 0000
DC-Frt Corner Rdar 2 -- Status: OK 0000
DD-Sunroof 2 -- Status: OK 0000
DE-Charger 1 for mobile dev -- Status: OK 0000
Address 01: Engine (J623-DDVB) Labels: Redir Fail!
Part No SW: 4K0 907 401 K HW: 059 907 309 L
Component: 3.0l V6 TDI H26 0003
Revision: CAH26--- CVN: 17249E2E7965F614755A21138947E11D00000000D6C3ECFE
Coding: 122A4012057E050334286000000400000000000000000000
Shop #: WSC 20574 006 1048576
ASAM Dataset: EV_ECM30TDI0114K0907401K 001003
ROD: EV_ECM30TDI0114K0907401J.rod
VCID: 2F3B036D379564B2869-807A
VINID: 9D196AAAA58221B780046188141C9BD136
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 4K0 927 158 AP HW: 0D5 927 156 P
Component: 0D5 30TDIRdW H05 0001
Revision: --H05--- CVN: 7D0A815600009238
Coding: 100000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_TCMALX52011 002015
ROD: EV_TCMALX52011_VW53.rod
VCID: 005990D1DA8B2BCA2F3-8054
ATF pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP H01 0705
Serial number: 1807050570
Address 03: ABS Brakes (J104) Labels: Redir Fail!
Part No SW: 4N0 907 379 AC HW: 4N0 907 379 P
Component: ESP9 Premium H06 0850
Dataset Number: 4K0909504H 0001 CVN: D11B0B40
Coding: 1CAA329731A30B9C51A44C991882D1E2F5B9C9384C8CD08A32188B47AF9D93
ASAM Dataset: EV_ESP9BOSCHCMP 004011
ROD: EV_ESP9BOSCHCMP_004_AU58.rod
VCID: 79AFFD35B9517A0268D-802C
Address 09: Cent. Elect. (J519) Labels:* 4N0-907-063-V2.clb
Part No SW: 4N0 907 063 DE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0652
Dataset Number: 4K0909514B 0023
Coding: 07000143C13900DD074C57889FFF8C68131B33100406009781010A001B3316810A450A0280100000000001000041081A0802000044010100000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 014010
ROD: EV_BCM1BOSCHAU651_014_VW53.rod
VCID: 74B1CC019E33076A3BB-8020
Wiper motor control module:
Subsystem 1 - Part No SW: 4K2 955 119 HW: 4K2 955 119
Component: J400FRWISCH 063 0730
Serial number: 00000001712010400656
Coding: 7DC727
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 21575373X81A955555A0
Coding: 02006E
Light switch:
Subsystem 3 - Part No SW: 4K2 941 501 A HW: 4K2 941 501 A
Component: E1 - LTM H09 0086
Serial number: 13S19.06.1800300877
Automatic dimming interior mirror:
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE101051823810556
Coding: 210000
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 H HW: 4K0 947 135 H
Component: Dachmodul H42 0413
Serial number: C00047361
Coding: 0D0101
Front windshield washer pump:
Subsystem 6 - Part No SW: 4N0 907 605 HW: 4N0 907 605
Component: J1100/SWP H09 0005
Serial number: 00000000001811600041
Coding: 020000
1 Fault Found:
405507 - Functional Limitation due to Energy Management
B10CD 00 [00001001] - -
[Function limitation due to energy management system]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 72
Mileage: 72531 km
Date: 2024.03.24
Time: 15:48:14
average_Voltage_terminals: 11.40 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 15.00 °C
interior_temperature: 19.50 °C
Vehicle speed: 0.00 km/h
Terminal activation-Terminal 75 status: On
Terminal activation-Terminal 15 status signal: On
Terminal activation-Terminal 15 via CAN: OFF
Terminal activation-Term 75: qualification: OFF
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4K0 907 561 E HW: 760 907 561 A
Component: LRR4R H04 0332
Dataset Number: 4K1909863L 0001
Coding: 5265FF5C78082C00010360E0000000BE4A1246484481009E00
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_VW53.rod
VCID: 303900112AAB7B4A9F3-8064
Address 15: Airbags (J234) Labels:| 80A-959-655.clb
Part No SW: 4N0 959 655 R HW: 4N0 959 655 H
Component: AirbagVW31 H35 2710
Serial number: 003U1M00AHKH Dataset Number: 4K0909602AC 0003
Coding: AACCF0C00CC00000985400FFF08D41AC00C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001028
ROD: EV_AirbaVW31SMEAU65x_001_VW53.rod
VCID: 4BC377FDA34D38928A1-801E
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2018169326100000
Coding: 04F001
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2018177307700000
Coding: 04F001
Crash sensor for side airbag: driver side:
Subsystem 3 - Part No SW: ----------- HW: 480 000 207 18
Component: SideSensor_Df 001 0887
Serial number: 35700000000DF5D0113N
Coding: 2D2D2D
Front Passenger's Side Airbag Crash Sensor:
Subsystem 4 - Part No SW: ----------- HW: 480 000 207 18
Component: SideSensor_Pf 001 0887
Serial number: 3580000000030CD4D03L
Coding: 2D2D2D
Rear Side Airbag Crash Sensor (on driver's side):
Subsystem 5 - Part No SW: ----------- HW: 480 031 206 18
Component: SideSensor_Dr 002 0149
Serial number: 351001C103A9ED6028DF
Coding: 2D2D2D
Passenger side rear thorax airbag crash sensor:
Subsystem 6 - Part No SW: ----------- HW: 480 031 206 18
Component: SideSensor_Pr 002 0149
Serial number: 352001C103A9A0912AC4
Coding: 2D2D2D
Crash sensor for front airbag: driver side:
Subsystem 7 - Part No SW: ----------- HW: 480 030 507 18
Component: FrontSensor_D 002 0149
Serial number: 355001C107E63A60CA6F
Coding: 2D2D2D
Crash sensor for front airbag: front passenger side:
Subsystem 8 - Part No SW: ----------- HW: 480 030 507 18
Component: FrontSensor_P 002 0149
Serial number: 356001C107EDFC20A85S
Coding: 2D2D2D
Center pedestrian protection crash sensor:
Subsystem 9 - Part No SW: ----------- HW: 480 032 506 18
Component: PedP_Sensor_C 002 0149
Serial number: 230001C10F435EB06BEG
Coding: 2D2D2D
Driver's side crash data pedestrian protection 2:
Subsystem 10 - Part No SW: ----------- HW: 480 002 506 18
Component: PedPSensor_D2 001 0887
Serial number: I0M000000008C6106FAC
Coding: 2D2D2D
Passenger's side crash data pedestrian protection 2:
Subsystem 11 - Part No SW: ----------- HW: 480 002 506 18
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000FD6106FAL
Coding: 2D2D2D
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
Component: Lenks.Modul H03 0005
ASAM Dataset: EV_SMLSKLOAU736 007012
ROD: EV_SMLSKLOAU736_VW53.rod
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 790 A HW: 4K0 920 790 A
Component: FBenRDWACC--- H11 0151
Dataset Number: 4K0909525B 0021
Coding: A58438E27C8806000193E160B080680008001000
ASAM Dataset: EV_DashBoardAU65X 001017
ROD: EV_DashBoardAU65X_001_AU58.rod
VCID: 2B03177D038D1892AA1-807E
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4N2 907 468 AB HW: 4N2 907 468 AB
Component: Gateway H14 0036
Revision: 8P020004 Serial number: 0488P798418704 Dataset Number: 4K0909515B 0028
Coding: 02010005000486408C960000005B0132DC9A004F18000000097D078E10000000
GVL: F1517C080804020082DC88000100C800110E0070010000000000000000000000
ASAM Dataset: EV_CGateCONTIAU491 003150
ROD: EV_CGateCONTIAU491_003_AU58.rod
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Serial number: 00000000000000000000
Battery Monitoring Control Module:
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Component: J367-BDMConti H03 1050
Serial number: 74186311001806090A6B
1 Fault Found:
8519683 - Energy Management Active
U140B 00 [00001000] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 112
Mileage: 72531 km
Date: 2024.03.24
Time: 15:48:04
EM_vehicle_state: 20 10
Static current shut-off stage: Deactivation stage 1
Auxiliary heater activation restriction request-Parking heater: Permitted
Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
Address 1B: Active Steering (J792) Labels: None
Part No SW: 4N0 907 144 C HW: 8W0 907 144 C
Component: SCU_MLBevo H03 0802
Serial number: 30303030303030 Dataset Number: 4K0909848G 0001
ASAM Dataset: EV_SCUZFLSAU65X 003019
ROD: EV_SCUZFLSAU65X.rod
VCID: 2E051E69309F6DBA8DF-807A
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 3Q0 905 861 C HW: 3Q0 905 861 C
Component: ELV-MLBevo H05 0020
Serial number: 17000400504018
Coding: 8800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW53.rod
VCID: 34310C01DEB3476AFBB-8060
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0042
Serial number: 00000331490072 Dataset Number: 4K8909856B 0013
Coding: 00781A400000B4010003010101010000000000000000000000000000004000
ASAM Dataset: EV_SCMDriveSideCONTIAU736 006009
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4N0 907 566 E HW: 4N0 907 566 A
Component: MRR_HR H12 0265
Dataset Number: 4K8909535D 0024
Coding: 5FFC00
ASAM Dataset: EV_RearRadarS1DelphAU651 001018
ROD: EV_RearRadarS1DelphAU651_VW53.rod
VCID: 38293831C2DBA30AD73-806C
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 793 D HW: 4M1 959 793 D
Component: TSG FS001 0188
Serial number: YE007RFK26676 Dataset Number: 4K8909872B 0025
Coding: 001DDA0152010480A009B032
ASAM Dataset: EV_DCU2DriveSideMAXHKLO 001010
ROD: EV_DCU2DriveSideMAXHKLO_VW27.rod
VCID: 40D950D19A0BEBCA6F3-8014
2 Faults Found:
196665 - Switch for Central Locking
B122D 29 [00001000] - Signal Implausible
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 110
Mileage: 72127 km
Date: 2024.03.14
Time: 19:26:06
196724 - Motors for Central Locking
B122B 13 [00001000] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 110
Mileage: 72127 km
Date: 2024.03.14
Time: 19:26:05
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Component: EPS_MLBEVO2BS H22 0505
Dataset Number: 4K0909852J 0004
Coding: E1002101010000
Shop #: WSC 31990 005 1048576
ASAM Dataset: EV_EPSVWBSAU426 010017
ROD: EV_EPSVWBSAU426_010_VW53.rod
VCID: 323D0A1924A7495AE97-8066
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 4N0 907 064 BP HW: 4N0 907 064 P
Component: BCM2 MLBevo H14 0145
Dataset Number: 4K8909501D 0037
Coding: 013500002FB100406309A0046C04C80203004000804F02502F0400000504823F001F0100010F01
ASAM Dataset: EV_BCM2CONTIAU651 008007
ROD: EV_BCM2CONTIAU651_008_VW53.rod
VCID: 7EA5EE29A07F5D3A5DF-802A
ID - sensor:
Coding: 000000
Anti-theft alarm system sensor:
Subsystem 2 - Part No SW: 5Q0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY181502LE6
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000099364862
left tail lamp 1:
Subsystem 4 - Part No SW: 4K0 945 217 HW: 4K0 945 217
Component: SHL_li1 003 0001
Serial number: 00000000000000151247
Coding: 000000
Rear lid opener control module:
Subsystem 5 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58522194
Rear spoiler control module:
left tail lamp 2:
Subsystem 7 - Part No SW: 4K5 945 093 D HW: 4K5 945 093 D
Component: SHL_li2 003 0001
Serial number: 00000000000000042371
Coding: 000000
Right rear tail lamp 1:
Subsystem 8 - Part No SW: 4K0 945 218 HW: 4K0 945 218
Component: SHL_re1 003 0001
Serial number: 00000000000000149521
Coding: 000000
Right rear tail lamp 2:
Subsystem 9 - Part No SW: 4K5 945 094 D HW: 4K5 945 094 D
Component: SHL_re2 003 0001
Serial number: 00000000000000062276
Coding: 000000
Address 47: Sound System (J525) Labels:* None
Part No SW: 4N0 035 223 C HW: 4N0 035 223
Component: MIB2_amp_P_D5 H01 0170
Revision: 00000001 Serial number: AUZ8ZAJ6S0029H. Dataset Number: 4K0909510A 0009
Coding: 0185020000AAAA2FAA0000010000
Shop #: WSC 00494 572 00000
ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
ROD: EV_AMPMst16C1Gen2pALPI_AU58.rod
VCID: 2411FC416E53D7EA6BB-8070
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M1 959 792 D HW: 4M1 959 792 D
Component: TSG BFS001 0188
Serial number: YE007RFR12294 Dataset Number: 4K8909873B 0025
Coding: 001DDA015E010480A009B030
ASAM Dataset: EV_DCU2PasseSideMAXHKLO 001010
ROD: EV_DCU2PasseSideMAXHKLO_VW27.rod
VCID: 3FDB532DE7F59432169-806A
Address 5F: Information Electr. (J794) Labels:| 4G1-035-MIB-HGH2.clb
Part No SW: 4K0 035 063 D HW: 4K0 035 063 A
Component: MU-H-LND-EU 046 2711
Dataset Number: 4K0909545E 0026
Coding: 0185020100000000C3111102C00800302F0001E601F008008E
ASAM Dataset: EV_MUHigGen2pALPI 001001
ROD: EV_MUHigGen2pALPI_AU27.rod
Data carrier:
Subsystem 1 - Part No: V03 959 807 SF
Component: MIB2P_EU_Q121 0520
Multimedia System 1:
Subsystem 2 - Part No SW: 4K0 919 605 C HW: 4K0 919 605 A
Component: DU AU58x High H42 0147
Serial number: INX00125041800060140
Compact disc data bank:
Subsystem 3 - Part No: V03 959 800 EG
Component: Gracenote2 1008
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004418000108473029
Multimedia System 5:
Subsystem 5 - Part No SW: 4K2 919 603 B HW: 4K2 919 603
Component: DU AU58x Bot H41 0147
Serial number: INX00124041800090246
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051800430849001
Address 61: Battery Regul. (J1120) Labels: 4N0-915-105.clb
Part No SW: 4N0 915 105 B HW: 4N0 915 105 B
Component: BMS_48V_LiIon H06 0108
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_BMS48VLiIonLGAU536 001001
ROD: EV_BMS48VLiIonLGAU536_AU58.rod
VCID: 290FED7509710A8258D-807C
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 F HW: 4M0 907 383 B
Component: Anhaenger H27 0253
Revision: 9A001003 Serial number: 0554018626 Dataset Number: 4K0909527A 0004
Coding: 0110000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 35373105D5C95E62CC5-8060
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0166
Revision: -------- Serial number: 31995017900000 Dataset Number: 4K0909541A 0008
Coding: 12F0
ASAM Dataset: EV_DeckLidCONTIAU736 001016
ROD: EV_DeckLidCONTIAU736_VW27.rod
Address 74: Chassis Control (J775) Labels:* Redir Fail!
Part No SW: 4K0 907 777 AS HW: 4K0 907 777 A
Component: Fahrwerk-SG H51 2016
Serial number: 0107180380 Dataset Number: 4K0909576G 0002
Coding: F45C3838DA40
ASAM Dataset: EV_ChassContrContiAU651 001011
ROD: EV_ChassContrContiAU651_001_AU58.rod
VCID: 084988F1F2BB138A673-805C
Air Suspension Compressor:
Subsystem 1 - Part No SW: 4M0 907 778 HW: 4M0 907 778
Component: V66LFKompOLV H06 0013
Serial number: 00000000004130350223
Coding: 303030
Address 81: Gear Shift (J587) Labels: 4KX-713-041-81.clb
Part No SW: 4K2 713 041 G HW: 4K2 713 041 H
Component: GSM-LL H14 0050
Serial number: 18.166 40087
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 2809E871127B338A473-807C
Address 82: Head Up Display (J898) Labels:* None
Part No SW: 4K2 919 617 A HW: 4K2 919 617 A
Component: HeadupDisplay H05 1808
Coding: 4700E2
ASAM Dataset: EV_HeadUpDisplAU65X 001010
ROD: EV_HeadUpDisplAU65X_VW53.rod
VCID: 33330F1DDBBD4052E21-8066
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* 4N0-907-107-V2.clb
Part No SW: 4KE 907 107 AC HW: 4N0 907 107 H
Component: zFAS Var C H09 0291
Dataset Number: 4K0909466J 0041
Coding: 04C184000000000000FFD60000F0D60C1B9F760000000000000000000096D401009BA8000000000000000080000000000000000000000000F980400000000000000078D0008000B000800080000000000080400000E0
ASAM Dataset: EV_ZFASAU516 001005
ROD: EV_ZFASAU516_001_VW53.rod
4 Faults Found:
2117711 - Internal Fault
B200F F9 [00001000] - Unknown Error Elaboration
[ZGT Überwachung am SRH fehlgeschlagen]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 112
Mileage: 72521 km
Date: 2024.03.24
Time: 11:41:02
Platform_zFAS_Error_Handler_Master-ErrorHandlerMaster: 01 00 48 11 93 11 00 00 00 00 00 00 00 00 00 00
Platform_zFAS_Error_Handler_SSH-ErrorHandlerSSH: FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Platform_zFAS_Error_Handler_SRH-ErrorHandlerSRH: FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00
221284 - Front Camera for Driver Assist Systems
C12B3 FD [00001000] - View Temporarily Restricted
[temp view limitations]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 109
Mileage: 72221 km
Date: 2024.03.15
Time: 15:08:21
EyeQ temperatures-CPU: -40 °C
EyeQ temperatures-VPM: 36 °C
Vehicle speed: 72.92 km/h
Front camera: blinding detection-Status: not active
Front camera: blinding detection-Blinding detected by light assistance assessment module: No
Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
Front camera: blinding detection-Blinding detected by object recognition assessment module: No
Front camera: blinding detection-Blinding detected by distance regulation assessment module: No
Front camera: blinding detection-Blinding detected by road profile estimation assessment module: Yes
Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
Front camera: blinding detection-Glare detected: No
Front camera: blinding detection-free view detected once: Yes
233523 - Parking Sensor(s); Front
B10FC F0 [00001000] - Function Limitation due to External Factors
[Geber für Einparkhilfe vorne - Funktionseinschränkung durch Umwelteinflüsse]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 109
Mileage: 72499 km
Date: 2024.03.23
Time: 14:04:58
65537 - Intersection Assistant
C12D8 F0 [00001000] - Status Feedback for HMI Implausible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 106
Mileage: 72333 km
Date: 2024.03.19
Time: 11:03:04
Profile master status intersection assistant-Nominal status: On
Profile master status intersection assistant-Actual status:: Initialization
Address AC: Reductant Control (J880) Labels: 80A-907-355.clb
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H07 0004
Dataset Number: 4K0909571D 0003
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
VCID: 2C01146106831FAAA3B-8078
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 4M1 959 795 D HW: 4M1 959 795 D
Component: TSG HFS003 0188
Serial number: YE007RG429833 Dataset Number: 4K8909897B 0025
Coding: 000DD80100010480A008B020
ASAM Dataset: EV_DCU2RearDriveMAXHKLO 001010
ROD: EV_DCU2RearDriveMAXHKLO_VW38.rod
VCID: 42DD5AD99407F9DA797-8016
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS003 0188
Serial number: YE007RG425699 Dataset Number: 4K8909896B 0025
ASAM Dataset: EV_DCU2RearPasseMAXHKLO 001010
ROD: EV_DCU2RearPasseMAXHKLO_VW38.rod
Address C4: DC/DC Converter (A7) Labels: 4M0-959-663.clb
Part No SW: 4M0 959 663 C HW: 4M0 959 663 C
Component: PCU10 022 0324
Dataset Number: 4K0909475A 0007
ASAM Dataset: EV_DCDC48V210ABOSCHAU736 001008
ROD: EV_DCDC48V210ABOSCHAU736_VW53.rod
VCID: 3A2D2239FCD7B11A217-806E
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 005 0002
Dataset Number: 4K0909469F 0014
Coding: 768040058203
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW27.rod
VCID: 75B7F10595491E620C5-8020
Address CB: Rear Axle Steering (J1019) Labels:* None
Part No SW: 4N0 909 145 L HW: 4N0 909 145 C
Component: HAL_MLBevoH03 0399
Revision: -------- Serial number: CCC_099_B_9056_ Dataset Number: 4K0909904K 0001
Coding: 42246200
ASAM Dataset: EV_RearAxleSteerZFAU736 010018
ROD: EV_RearAxleSteerZFAU736_010_VW53.rod
Address CC: Starter-Generator (----) Labels:* None
Part No SW: 4N0 903 028 H HW: 4N0 903 028 H
Component: BSG-HP1-65 H16 0523
Serial number: 10071800020262
Coding: 28000000000000
ASAM Dataset: EV_Start48VAU651 001006
ROD: EV_Start48VAU651_001.rod
Address CD: Laser Scanner (J1122) Labels: None
Part No SW: 4K8 907 660 C HW: 4N0 907 660
Component: LASER_SCANNER H36 0205
Dataset Number: 4KA909639F 0005
ASAM Dataset: EV_LaserScannAU651 013017
ROD: EV_LaserScannAU651_013.rod
VCID: 36353609C8CF557AC5F-8062
Address CF: Lane Chge Asst 2 (J770) Labels:* None
Component: MRR_HL H12 0265
Dataset Number: 4K8909468D 0024
Coding: 5FFC00
ASAM Dataset: EV_RearRadarS2DelphAU651 001018
ROD: EV_RearRadarS2DelphAU651_VW53.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 4K0 941 592 BC HW: 4K0 941 592 B
Component: LMS_MLBevo H11 0032
ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X_AU27.rod
VCID: 72BDCA19E427095A297-8026
Dynamic left front turn signal:
Subsystem 1 - Part No SW: 4K0 941 035 HW: 4K0 941 035
Component: M134DynTurnFL 003 0004
Serial number: 06122100075268001011
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LMS_MLBevo H10 0030
Dataset Number: 4K0909472H 0014
ASAM Dataset: EV_LMSRightHELLAAU58X 001013
ROD: EV_LMSRightHELLAAU58X_AU27.rod
Dynamic right front turn signal:
Subsystem 1 - Part No SW: 4K0 941 036 HW: 4K0 941 036
Component: M135DynTurnFR 003 0004
Serial number: 27111700001122001011
Address DB: Frt Corner Rdar 1 (J1089) Labels:* None
Part No SW: 4N0 907 669 E HW: 4N0 907 669 A
Component: MRR_VR H12 0265
Dataset Number: 4K8909482C 0017
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS1AU651 001018
ROD: EV_FrontCorneRadarS1AU651_VW53.rod
VCID: 3C212421F6E38F2A33B-8068
Address DC: Frt Corner Rdar 2 (J1088) Labels:* None
Component: MRR_VL H12 0265
Dataset Number: 4K8909483C 0018
Coding: 003000
ASAM Dataset: EV_FrontCorneRadarS2AU651 001018
ROD: EV_FrontCorneRadarS2AU651_VW53.rod
Address DD: Sunroof 2 (J392) Labels:* None
Part No SW: 4K0 907 594 AD HW: 4K0 907 594
Component: SAD_STG_2 005 0002
Dataset Number: 4K0909581C 0010
Coding: 729000058204
ASAM Dataset: EV_SunRoof2CONTIPO623 009011
ROD: EV_SunRoof2CONTIPO623_VW37.rod
VCID: 76B5F609884F157A05F-8022
Address DE: Charger 1 for mobile dev (J1146) Labels:* 4N0-035-502.clb
Part No SW: 4K0 035 502 A HW: 4K0 035 502 A
Component: WLC Front H10 0061
Coding: 400000
ASAM Dataset: EV_Charg1MobilDevicAU651 004001
ROD: EV_Charg1MobilDevicAU651_004_VW53.rod
VCID: 1F1BF3AD4735F432369-804A
End----(Elapsed Time: 02:42, VBatt start/end: 11.5V/11.3V. VIgn 11.3V)-----
Saturday,30,March,2024,14:10:28:33420
www.Ross-Tech.com
VIN: WAUZZZF28KN016685 License Plate: X31ADAA
Mileage: 72982km-45348mi Repair Order:
DE
VIN: WAUZZZF28KN016685 Mileage: 72982km-45348miles
01-Engine -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
81-Gear Shift -- Status: Malfunction 0010
1 Fault Found:
36650 - Start/Stop System; Maximum Time for Restart Exceeded
P167E 00 [00100000] - -
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 72908 km
Date: 2024.03.28
Time: 19:27:06
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 88 °C
Intake air temperature: 13 °C
Ambient air pressure: 960 mbar
Voltage terminal 30: 11.520 V
Unlearning counter according OBD: 39
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
Coding: 100000
ATF pump:
Coding: 1CAA329731A30B9C51A44D991882D1E2F5B9C9384C8CD08AB2188B47AF9D93
Coding: 07000B43C13D00DD074C57889FFF8C68131B33100406009781030A00993316810A450A0290100000000001000041091A0802050044010100000000000000000000
Coding: 7DC727
Coding: 02006E
Light switch:
Coding: 210000
Coding: 0D0101
Coding: 020000
Coding: 04F001
Coding: 04F001
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: A58D38E27C9806020193E760B080780018001000
GVL: F1557C080804020082DC88000100C800110E0070010000000000000000000000
Coding: 5FFC00
Coding: E1062301010000
Coding: 01350000EFB100406309A004FD04C80203004000804F02502F0400000504823F001F0100010F01
ID - sensor:
Coding: 000000
Alarm horn:
left tail lamp 1:
Coding: 000000
left tail lamp 2:
Coding: 000000
Coding: 000000
Coding: 000000
Data carrier:
Volume Control 1:
Media socket:
1 Fault Found:
7178 - Function Restricted due to Missing Message(s)
U1111 00 [00001000] - -
[Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 14
Reset counter: 127
Mileage: 72936 km
Date: 2024.03.29
Time: 21:08:44
Voltage terminal 30: 15.2 V
BAP-BAP_Function_ID: 2E
Coding: 12F0
Coding: F45C3838DA60
Coding: 303030
1 Fault Found:
3003 - Switch for Parking Lock
P18CB 00 [00001000] - Implausible Signal
[P_Button_Implausible]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 127
Mileage: 72936 km
Date: 2024.03.29
Time: 21:08:15
Voltage terminal 30: 15.40 V
Selec. range display: spec. val.-Text: R
Selector lever position-Text: Basic setting X
Inside temperature: 22.50 °C
System run time-Hours: 0 H
System run time-Minutes: 26 min
System run time-Seconds: 48 s
Coding: 4700E2
Coding: 04C184000000000000FFD60000F0D61C1B9F760000000000000000000096D401009BA8000000000000000080E0000000000000000000C000F980400000000000000078D0008000B000800080000000000080400000E0
1 Fault Found:
2114634 - Databus
U1123 00 [00001000] - Received Error Message
[Waehlhebel_04_WH_P_Taste]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 127
Mileage: 72936 km
Date: 2024.03.29
Time: 21:08:15
Coding: 42246600
Coding: 5FFC00
Coding: 003000
Coding: 003000
Coding: 400000
End----(Elapsed Time: 02:34, VBatt start/end: 11.6V/11.5V. VIgn 11.5V)-----
ENG157971-ENG161298,Intelligent Park Assist-00: Waehlhebel_04 WH_Sensorpos_roh != {X: M: Init: Fehler},No,
ENG157971-ENG161299,Intelligent Park Assist-01: P Taste betätigt,No,
ENG157971-ENG161300,Intelligent Park Assist-02: Tip paddles betätigt,No,
ENG157971-ENG170226,Intelligent Park Assist-03: IPA angelernt,Yes,
ENG157971-ENG161301,Intelligent Park Assist-04: Fahrbereitschaft vorhanden,No,
ENG157971-ENG161302,Intelligent Park Assist-05: GSG verfügbar,No,
ENG157971-ENG161303,Intelligent Park Assist-06: Parksperre ist richtig eingelegt,Yes,
ENG157971-ENG161304,Intelligent Park Assist-07: Geschwindigkeit < p_v_IPA_PP_Fzg_Stillstand,Yes,
ENG157971-ENG161305,Intelligent Park Assist-08: Geschwindigkeit < p_v_IPA_PP_MA_vmax_Eingriffe_Aktoren,Yes,
ENG157971-ENG161306,Intelligent Park Assist-09: Geschwindigkeit < p_v_IPA_PP_Fahrstufenwechsel,Yes,
ENG157971-ENG161307,Intelligent Park Assist-10: Geschwindigkeit ist intern gebildet,No,
ENG157971-ENG161308,Intelligent Park Assist-11: Geschwindigkeit ist konstanter Ersatzwert,No,
ENG157971-ENG161309,Intelligent Park Assist-14: IPA-relevanter Fehler im GSG vorhanden,No,
ENG157971-ENG161310,Intelligent Park Assist-16: IPA_01 Timeout vorhanden,No,
ENG157971-ENG161311,Intelligent Park Assist-17: IPA_01 BZ oder CRC Fehler vorhanden,No,
ENG157971-ENG161312,Intelligent Park Assist-19: Klemme 15 EIN,Yes,
ENG157971-ENG170227,Intelligent Park Assist-31: SWI_IPA_Verbaut != 0,Yes,
ENG157971-ENG162658,Intelligent Park Assist-GE_Status_GE_IPA,7,
ENG157971-ENG162948,Intelligent Park Assist-IPA_Fahrstufenwunsch,1,
ENG157971-ENG162950,Intelligent Park Assist-IPA_Status_IPA_GE,0,
ENG157971-ENG140920,Intelligent Park Assist-Value,2423784392,
looking at ) 01/02 any help much appreciated
MAS12843-Maneuvering brake function,activated ,1
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated ,64
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,not activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
