SD card not working
Young un
Just wondering if any could help
Im using 256MB Toshiba SD card with only a few music files but it isnt recognised. The unit keeps reading "data corrupted".
I've simply "copy" and "paste" the mp3 files from computer onto the SD card. I also tried setting up a folder and "copy" and "paste" the files likewise. Still no luck!!
I then made an mp3 audio CD using the exact same mp3 files. This worked a treat.
I dont realy intend to use the SD card slots for music, but I've realised that the DVD navigation is disabled if Im using the mp3 audio disc. I'll eventually connect my ipod to the headunit, but I got to remake and new docking station first.
Any thoughts on the SD card issue?
Dan
Was the card formatted before you tried to put all of the songs on it? Sometimes if you take a card from another device and dont format it they dont like it, certain phones are a prime example.
Failing that are the files in the right format?
Rich
I found that when I copied the music folder to the SD card it didnt work. Then I realised that in the folder there were hidden files and thats what confuses the car. Copy each song individually, not in folders and it should be ok. But I'd also format the SD card to make sure theres nothing else on it.
Coss
Thanks, I'll only copy each file individually then to avoid "copying over" any errorenous files.
Apologies for this next question though. I've no idea how to format the SD card. I've just deleted all files/folders that is currently stored on it - surely that isnt formatted??
Thanks again
You'll need to go to 'My Computer' on your PC. You should then see your SD card appear as a drive letter (i.e. D: or E: etc.)
Right mouse click on the correct drive that is your SD card and select format.
In the options that appear, make sure you chose to format the card as FAT32 as Issac said in an earlier post. Click OK and it should format.
Also make sure when copying MP3s across that file names are shorter than 64 characters.
Plenty of info on SD Cards here
It's the total file path (name + folders) that needs to be less than 64 characters.
545
9
951
658
12
598
