VAG-COM SCAN FAULTS - HELP
singhl
I have and A6 3.0tdi quattro 2004 (4F), updated the MMI to the latest version and, lost the battery manager (got it back following a post foind on net, adding 32 to channel 2 on address 7).
But there is one problem in the vag-com scan I cannot clear:
I have done a scan as below:
VCDS Version: Release 805.3
Data version: 20090213
Tuesday,24,February,2009,17:43:30:15531
Chassis Type: 4F0
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 76 77
VIN: WAUZZZ4F55N008859 Mileage: 117400km/72948miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
61-Battery Regul. -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 F HW: 4F0 907 401 A
Component: 3.0L V6TDI G000AG 0030
Revision: --H01--- Serial number:
Coding: 0011772
Shop #: WSC 66565 257 00032
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F0 910 156 H HW: 09L 927 156
Component: AG6 09L 3.0lTDI RdW 0110
Revision: 00000001 Serial number: 0019503
Coding: 0000001
Shop #: WSC 00006 210 89785
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 A HW: 4F0 614 517 A
Component: ESP8 quattro H03 0330
Revision: 00000000 Serial number: 00000000000000
Coding: 0004488
Shop #: WSC 02335 785 00200
Address 05: Acc/Start Auth. Labels: 4F0-910-852.lbl
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600200021071
Coding: 0000023
Shop #: WSC 00762 210 91708
Part No: 4F0 910 131 G
Component: FBSAUDIC6 EZS H43 0060
Part No: 4F0 910 335
Component: FBSAUDIC6 KSG H25 0060
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 350DA047510324
Coding: 0000002
Part No: 4F0 910 609
Component: Bedienteil MMIC6H03 0870
3 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 117284 km
Time Indication: 0
Date: 2009.02.24
Time: 16:08:39
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 172
Mileage: 115018 km
Time Indication: 0
Date: 2009.02.09
Time: 12:57:45
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0000000
Bin. Bits: 001
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 172
Mileage: 115018 km
Time Indication: 0
Date: 2009.02.10
Time: 05:51:48
Freeze Frame:
Bin. Bits: 10
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043 C
Component: KLIMABETAETIGUNGH11 0060
Revision: 00000021 Serial number: 00000000016249
Coding: 0009238
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0012121
Part No: 4F2 910 113
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 02335
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0040
Coding: 00141886
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000000 Serial number: AUZ5ZBD2005499
Shop #: WSC 00000 000 00000
1 Fault Found:
02261 - Media Player; Position 1 (R118)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 7
Fault Frequency: 2
Reset counter: 184
Mileage: 115874 km
Time Indication: 0
Date: 2009.02.14
Time: 13:17:58
Freeze Frame:
Text: 00000000
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 G HW: 4F0 959 655
Component: 20 AIRBAG AUDI8RH24 0110
Revision: 07H24000 Serial number: 00358D058E6J
Coding: 0012848
Shop #: WSC 00762 210 83614
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H06 0130
Revision: 00H06000 Serial number: 90025041200216
Coding: 0102141
Part No: XXXXXXXXXXX
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 H
Component: KOMBIINSTR. M73 H07 0460
Revision: 00600000 Serial number: 49F313K44
Coding: 0001443
Shop #: WSC 54064 210 66681
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 08008044230254
Coding: ECFE73C41B3104
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 196
Mileage: 116894 km
Time Indication: 0
Date: 2009.02.21
Time: 13:40:03
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 E HW: 4E0 919 887 C
Component: MNS ECE H43 1050
Revision: 00000000 Serial number: 353DP047515556
3 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 200
Mileage: 116591 km
Time Indication: 0
Date: 2009.02.18
Time: 16:55:00
Freeze Frame:
Hex Value: 0x49A4
Hex Value: 0x2C5A
Hex Value: 0x0000
Hex Value: 0x2AAD
03183 - Data Media not Compatible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 192
Mileage: 116591 km
Time Indication: 0
Date: 2009.02.18
Time: 16:57:13
Freeze Frame:
Hex Value: 0x499C
Hex Value: 0x3DE9
Hex Value: 0x0000
Hex Value: 0x9494
02927 - DVD Read Error
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 192
Mileage: 116591 km
Time Indication: 0
Date: 2009.02.18
Time: 16:55:01
Freeze Frame:
Hex Value: 0x499C
Hex Value: 0x3D75
Hex Value: 0x0201
Hex Value: 0x0204
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 793 B
Component: TSG FA H10 0020
Revision: 00000000 Serial number: „
Coding: 0017018
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01000172500000
Coding: 0140787
Part No: 1K0 951 605 A
Component: LIN BACKUP HORN H01 1201
Part No: 4F0 910 177
Component: Innenraumueberw.H01 0010
1 Fault Found:
01565 - Luggage Compartment Light (W3)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 4
Reset counter: 156
Mileage: 116894 km
Time Indication: 0
Date: 2009.02.21
Time: 13:54:12
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 00000001 Serial number: 02904040009669
Coding: 0000003
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H07 0040
Revision: Serial number: 00000000008460
Coding: 0001103
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 B HW: 4F0 959 792 B
Component: TSG BF H10 0020
Revision: 00000000 Serial number: 2Y
Coding: 0017018
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C43HC002 H03 0020
Revision: C43HC002
Coding: 0000321
Shop #: WSC 02334 785 00200
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 A
Component: Dynamische LWR H01 0010
Coding: 0000003
Shop #: WSC 02327 785 00200
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0630
Revision: 00000000 Serial number: 352DI047520680
Coding: 0000001
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000009239
Shop #: WSC 00778 210 91838
Part No: 4F0 915 105 D
Component: von VA0 0404210082
Coding: 344630393135313035442056413030343034323130303832
Shop #: WSC 00000 640 00290
Address 62: Door,Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
Coding: 0016426
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Coding: 0016426
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0020
Revision: --.--.-- Serial number: 11730410104003
Coding: 0001006
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 C
Component: TELEFONMODUL EU 0770
Revision: 00000003 Serial number: T2AUDX0307H326
Coding: 0000006
End ---------------------------------------------------------------------
Everything clears apart from the control head first error i.e.
Coding: 0000002
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 159
Mileage: 117284 km
Time Indication: 0
Date: 2009.02.24
Time: 16:08:39
Any ideas about this - from what I can see, it is set up correctly for my car, and I cannot see any adaptions that need changing?
The car is a 4 door saloon.
12
3K
12
