Annoying Vag-Com Fault
aristides
Greece
Hello fellas
Does anyone know what this ****** thing mean? I`ve had it for quite some time and still cant figure out what`s causing it!
00469 - Infotainment Databus in Single Wire Operation
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 169
Reset counter: 200
Mileage: 39566 km
Time Indication: 0
Date: 2010.04.09
Time: 14:03:45
I`ve had my RNS-e for about a year now, and never had this Fault.
It suddently appeared, and i cant recall what i did , so i can fix it :S
Please note that everything is working fine (Navigation, Radio, Bluetooth etc)
I`m just seeing the fault in Vagcom and its driving me mad!
Found this answer on audiforums
Either the CAN H or CAN L connection on the Infotainment CAN is not connected so it's only using one of the CAN wires, hence the error message.
Any ideas how it got disconnected? How could i fix that?
Which parts of the car have you disturbed recently? You could have accidentally broken one of the wires.
Hmm let me think.
I removed the Climatronic to retrofit the non smokers thingy + illumination, but never got next to any wires. I just used the plug from the ashtray and connected it to my new led stripe
I actually had to remove the whole center console cause i lost a bolt but i remember not ripping any wires apart.
What problems would cause this fault? Everything is working just fine now
Ok all sorted, had a look around and realised that the CAN wires of my BT module were not connected to the Car CAN wires anymore after i removed my RNS-e the last time
Thanks for the help guys
921
663
702
