Not necessarily. But they are what most people here have mentioned as a direct fit. I have 2 gripes with these though. The one marked Right side is an L shaped fan, which seems a little odd and uneccissary. Moving it to the left side was an improvement but the asymmetry doesn't make sense to me... but then I'm a bit OCD so take that with a grain of salt. I didn't really like them if I'm honest, and went looking for a standard fan pattern, but after 2 attempts with the plug being the wrong pin size I just want back to the stock ones!
I've been tempted to get 2 left side fans, which I think would work pretty well... but don't experiment on my account.
My other gripe is that these part number use a torx bit for adjustment which is rather stiff, and it is fairly hard to find a bit to comfortably fit down there to make adjustments. Other styles use a slotted screw which is much easier.
And they all do spray just a little bit low, and if you adjust too high it just hits the underside of the bonnet.
Hope that's helpful and I'm sure others will chime in.
