Hello everyone.
Hopefully someone can help on here. Recently bought a 2001 1.9 tdi pd 130sport and love it apart from the fault is has suddenly developed. When it is cold it is usually fine however once warm it runs perfectly find on idle but judders through the cabin. It has had the flywheel done 4k milles ago and no fault codes for the engine dampner so i am thinking it could be this that need adjusting - TDIClub Forums - View Single Post - injection pump repair, fuel quantity
However more annoyingly when its warm driving normally it runs well through the rev range. But when accelerating hard it cuts out / chugs / coughs above the 2k rev range to the red line. There are no fault codes in the ecu.It does drive through it to the red line and doesnt go into limp home mode, nor does it smoke. It normally happens at around the 3k rpm mark and only does so on wide open throttle. Its getting quite annoying now and what to get this sorted out asap as i want to send it to be remapped but not untill i know its running as it should.
Any help or suggestions would be greatly appreciated.
Ian
Ian
