Hello boys,
mary_q
Hello boys,
Will wheels as following fit on my 1999 A3?
Stud Diameter: 100
Rim Width: 7.5J
Rim Diameter: 17
Number of Studs: 5
Cheers :beee:
The ad says 5x100 stud diameter, so they should fit...
ah really? i specified this in my first post and they queirrd about offset/et??
is the 5x100 relevant to that?
Mary, check out here, this will explain the offset that was being queried.
The 5x100 is the Pitch Circle Diameter (PCD).
The 5 relates to the number of studs in your mounting flange, 100 relates to the diameter of circle the studs lie on (imagine a 100mm circle, the centres of the five stud holes on your hub mounting flange will all sit on that 100mm circle)
833
581
660
