For the record, using them both at the same time will kill communication speed... I am not even sure the communication bus will support 2 devices trying to sample data at the same time which is generally why VCDS logs a max of 3 blocks at a time... the older K-Line communication on 8L's is not fast at all.
This is why I ended up hard wiring mine (which isn't that difficult tbh) and switching the K-Line wire between the Liquid and the OBD socket for VCDS... in particular any extra 'noise' that may be introduced could potentially brick your ECU if you are having it flashed for whatever reason... Old Ibiza's are particularly prone to poor communications and generally need to be bench flashed.
I wouldn't recommend running both together but I understand having to enter the pwd every time is a royal PITA which is why mine is on a switch power feed from the OBD socket so even when I switch between Liquid and the socket the Liquid still has power.
