http://wiki.ross-tech.com/wiki/index.php/17704/P1296/004758
17704/P1296/004758 - Error in Mapped Cooling System
http://wiki.ross-tech.com/wiki/index.php/17863/P1455
17863/P1455 - Exhaust Gas Temp Sensor 1 (G235): Implausible Signal
http://wiki.ross-tech.com/wiki/index.php/17511/P1103/004355
17511/P1103/004355 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
Thermostat needs changing, EGT sensor sounds like its on its way out and maybe due to the over rich fuelling the lambda probe has bought the farm...
Have you cleared the codes to see which ones return in case these are legacy of a previous issue that was fixed? if not, clear them and see which come back...
If they all come back then change stat, replace lambda probe, clear codes and see if the EGT one returns... if it does then unfortunately you might have to fork out for one...
