No water from rear washer
SiGainey
North Wales
Yeah, I know... There's loads of threads and I've searched and can't find one which describes my symptoms - I push the stalk backwards to run the rear wiper. There's a leak by the drivers side headlight, right by the washer bottle... But it's dripping DOWN onto the washer bottle if that makes sense...
So where does the washer pipe go from the washer bottle lol!
the pipe connects there to the rear wiper if you rear move the evap tank you will see like a three way system there mite be a split pipe there as i had the same problem mate hope that helps
Sorry, being a newbie, the evap tank? Is that the charcoal canister that ticks all the time? How do you get to this three way join?
yh it is mate just undo the one bolt that holds it down on the engine mount mate if you look you will see it
Spot on Tony - the hose had actually come apart in two places (just by the washer bottle and in the trunking near the airbox), but it's back together again now and it works a treat!. Cheers for your help :)
13
