Kufatec Sportback rear light adaptor
b19ctr
The King of Cannock
Cannock
Anyone fitted the kufatec rear light adaptor to upgrade there Sportback rear lights?
I've fitted them and there working fine apart form the reverse and fog lights wont come on anyone know what the issue is?
Chris
you may have to move a few pins around
whats the point of adapters if u have to move pins about. doubt its that. isnt it to do with vagcom?
i was going on the last set i fitted
fog didnt work and i had to move pins
All sorted now I'll find out what the garage did to get them to work :)
On a side note, the Kufatec website states these lights are not suitable for RHD. Where can i get facelift sportback lights which are suitable?
RHD and LHD only applies to the 3dr model as it relates to which side of the vehicle has the fog light, on the 5dr it doesn't matter as both sides have them in the tailgate lights rather than the outer lights
Thats kufatec for you, but the pins on either side arent identical in location, they would have to be moved to suit according to elsawin.
you need to move pins around and then use vcds for all prefacelifts
post facelift, no adaptor needed ; only vcds
