s3 full boost problem
Delaney1
hey guys
few days back had a coil pack go down so did the decent thing and replaced all 4(gsf coil packs)
been driving it around for a few days fine
went out for a lil spin last nite was running supurb all nit untill at the end of the nite it developed a problem seems to be down on a bit of power through rev range and when on full boost it wot i can discribe as hit fuel cut / miss fire.
runs perfect up2 about 1.2 bar boost then this problem happens
any1 had this problem or can fink ov anything iv missed to look at ?
its recent plugs fuel filter coil packs im stuck please help! Thanks Dave
iv done some research seems on the AGU's the ignition module is common am i rite in saying mine dosnt have 1 (apy) ?
any help would be appriciated im stuck !!!
What plugs did you fit? NGK PFR6Q are the correct ones. The plugs are more than likely where your issue is. hth.
fitted new bosch super plus fr7kpp33+ today made no difference
i cnt work out wot it is
Hmmm that's an odd one. I once had an issue with a new set of Gsf coilpacks on an apy overheating and a sticky spooge coming out the top of them. Maybe try a mates coilpacks to rule it out?
sounds like the exact problem I had mine was a coilpack that only misfired under full load. Did you keep your old coils? If you can get it scanned on vcds, if not then maybe you could try swapping one of your old coilspacks on each cylinder see if it goes?
done it all lol ****** car i have a feeling its fuel related
its going back up 2 badger 5 on thursday nite so hopfully have result from that
Thanks for the replys tho
i had the same problem.
Water was coming in thru secundairy airpump.
disconnected the hose on the airbox and covered the hole-> problem was solved.
im running aftermarket air filter (no airbox)
it really is a strange 1
5K
13
