constant little knocking from the rear.
tdi-man
think my rear top mounts are gone got a constant little knocking from the rear .
ordering new shocks at the same time..
any think else worth doing while working on the rear ?
i would check the condition of the rubber mountings that go on top and below the springs too while your there as over time they can perish
I get a bumping noise at the back and think it's the plastic undertrays on the swing arms they certainly feel a bit loose and rattle about a bit, maybe worth checking before you pull your suspension apart.
Alan
NEW rear shocks and top mounts and bump stops and shock sleeves fitted ...NO MORE KNOCK...
How much for it all (as mentioned) if you don't mind me asking? I think I need this done.
all parts trade came to £90 ish and half hour to fit
how much were your top mounts mate ?, glad you got it sorted tho i bet its so much better to drive now
£15 each plus got new bumps stops cause they changed the shape of them
I need to do this the rattle is sooooo annoying! Where did you get the parts from, stealers?
m8 got me shocks cheap but rest of bits from tps
24
imported_S_Line
I
44
3K
571
284
