my front brakes keep clunking when i brake, and its becoming a pain so wondered if anyone has idea of decent solution.
i have 312mm discs fitted and just before xmas i fitted new pagid front pads, and they were fine then after abbut a month they started to make a clunk when brake , and it also does it if you press when stopped. if you press pedal hard they stop doing it for a bit then start again.
i took them apart cleaned them and put new copper grease etc back on and was all good again for about 6 weeks then started again, so did the same and was good til now.
its almost as if the pads are slighty loose in the caliper, and whilst the grease is there they stop but as it dries/wears or washes off etc they become loose.
i ahd read on audizine that someone had same problem and he stopped it with abit of tap round ends of the pads where they sit in the caliper, was thinking doing same but by using heat shrink as it will look neater and wouldnt undo
but looking for ideas...........as really dont want to have to fork out for new pads again unless i have to
