New RNS-e questions
A3simon
Aberdeen
Just installed a new version G RNS-e and have some questions
how do i get the phone contacts onto the rns-e do i need to change a code
how do i get the start up screen to show S3 instead of MMI
Anything else thats worthwhile switching on in the system
Startup screen would be in 37 navigation adaptation channel 18 iirc, set to a 1, you need bluetooth for contacts, do you have this, if so you need to code 77 BT for rns-e high with diag via can & 37 RNS enable telephone integration along with 16 steering wheel.
startup screen done
as for the other stuff i cant see any of the stuff your talking about
When you login to 77 it should popup a window advising what coding is what, that will clearly show you what I'm advising, you have to click on coding 1st mind you.
10
3K
