Andy123
194 g/s at 5200rpm and at 18psi doesn't seem that bad does it? lol
Looking at Tufftys old logs, just over 22psi at 5040rpm getting 240 g/s
I haven't seen that log mate- I will have a look if I can find it.
You want to put your foot down more for the logs, its taken you 8 seconds to get from 2.5k to 5.5k ??
Ive got some 10mm stainless pipe that will bend easily if you are still having heat issues....
Really, it seems a long time....glad you got the brakes sorted..My foot is planted on the floor Dave! Logged in 3rd gear. I've sorted out the issue with the brake servo thanks, bent some 10mm ali tube myself and modded the original fitting a bit so hopefully I won't have any issues with that now.
Off topic but Can't believe iv only just seen this. That looks amazing dude nice colour choice.
Bet you'v never been told " I like Yr rear end" as much in Yr life
It may be worth sending them the picture?, i would be very upset if they are leaking, you cant get a decent job done these days....tell tale for them seals are very smokey exhaust from cold/overnight, then left on idle when hot they smoke..
maybe the cause of your running issues?
That's a real shame it had to be split open again. Was there any play of the valve in the guide?
Also, did you change breather setup by any chance?
why can I only press like once! that sounds amazing
Id have totally been there if I'd have known. glad it feels better mate.
Sounds really nice. It's so much easier to deal with someone in the uk then to be sending emails back and forth to canada. Bill is over 2 hours away from me but I'd rather go to see him then anyone else.
Car sounds great Andy and Bill certainly knows how to get these cars running right. I wouldn't mind seeing your car in the flesh, love the work you've done on this.
Thanks Andy. I can get it out of the garage now and finally start to drive it properly!
Great outcome Andy! Graphs look great. Id be happy with that! Suppose if the EGTs are down then it just shows how good a job you made of all your fabrication!
