Spigot Ring for 19" Alloys
mubzy79
Hi I have some 19" Oettinger alloys which are ET35 and obviously 112 PCD. I tried fittign them to my car yesterday but They weren't sitting flush on the car so I am assuming I need some Spigot Rings. Has anyone had any experience of this and do I need a Spigot Ring and if so what size?
Spigot rings work fine, you will neeed to reduce the CB on your new wheels using a spigot ring eg 73.1-57.1(vag standard)..If you don't use spigot ring's you will have wheel wobble due to the wheels not being centered/sitting on the hub's.
Is there much difference quality wise between the Metal and the Plastic ones?
Plastic or metal it makes no difference they are a fit and forget item..
i was referring to the alloys not sitting properly on the hub
Do you know the size of the CB on the new alloy wheels..
do you mean they wobble, and fall off if there are no bolts in, the spigot rings hold the wheel on the hub perfectly central so that when you put the bolts in they stay central and dont wobble which is 57.1
I understood flush to mean you wheels are sitting inside or outside the arches, then it would be spacers
12
5K
CMD
I
995
10
995
