1/4 mile times of S3's
adcooper
Audi A6 C6 Avant 3.0tdi Le Mans S-Line
Birmingham
Can anyone help the search seams to be up the spout? What’s the 1/4 mile time of a standard 225 S3? /ubbthreads/images/graemlins/book.gif
Just one more thing I am thinking of the Revo upgrade what difference does this make to the 1/4 mile and does anyone recommend this upgrade?
Thank you for any advice.
/ubbthreads/images/graemlins/jump.gif
Ive had the Revo upgrade and love it.
Highly recommended by myself /ubbthreads/images/graemlins/ok.gif
14.3 that sounds good to me 13.8 sounds even better.
You had any problems with the Revo Taffy, does it make that much diffrence??
/ubbthreads/images/graemlins/woohoo.gif
Had it done about 3mths ago now and after the 5hr free trial I had to have it.
It takes it from 210 to about 265bhp which is a very noticeable difference /ubbthreads/images/graemlins/groovy.gif
Put it this way I smiled a lot driving the car before, but now I cant take the grin of my face /ubbthreads/images/graemlins/woohoo.gif
Now problems since having it done either /ubbthreads/images/graemlins/smile.gif
Auto car did a test on the standard 225 S3 and they quoted 15 secs dead at 94mph for the standing quarter.
I'd think 13.8 secs for a chipped one is being a bit optimistic!
assuming 265hp real power, it should be about 14secs 1/4 mile with a terminal speed of about 100
according to http://www.letstorquebhp.com/ and thier figures correlate well with the measured ones for the 225hp s3
[ QUOTE ]
Much diff in the MPG?
[/ QUOTE ]
Not really !! its still crap
Averaging 28mpg ish on the DIS /ubbthreads/images/graemlins/beerchug.gif
/ubbthreads/images/graemlins/cry.gif
So standard its 15???? Thats a bit poo ent it?
/ubbthreads/images/graemlins/soap.gif
I've managed a 14.3 @ 93mph. I thought that was pretty good, but it turned out I had a faulty MAF sensor (it wouldn't hold boost).
MAF changed, I tried again... this time with 19's on... 14.3 again.
Both time running a 1.1bar boost.
I think high 13s are easily achievable with a higher boosting map.
What is the std boost level then? You running +/- 265?
The best I ever managed was 14.5 on 19".
Grant has proven that the bigger wheels, surprizingly don't make that much of a difference.
I did see an older one do sub 14 though. Remember the pre-facelift cars are lighter.
[ QUOTE ]
[/ QUOTE ]
ive seen many standard S3's run 14.5 at santa pod... Think the fastest was 14.45 for a standard S3. sub 14's are doable in a chipped S3.
Rich
[ QUOTE ]
[/ QUOTE ]
When I first got 14.3, the boost would hit 17psi then fall to 10psi on every gear... hence faulty MAF.
The second time I got 14.3 was when I had 19s on... 17psi boost dropping to 15psi.
High boosting S3's should get into the 13s.
[ QUOTE ]
[/ QUOTE ]
Rolling roaded at Star after fitting my Supersprint exhaust was 270bhp... peak boost 17psi.
My ECU has since been mapped again by AmD with a more agressive map, although I'm still not boosting high enough - I need to try a new MAF I think.
So 14.5 is about it for standard, at least thats better than my 172 i part xed?
to be fair.. i would quote around 15.2 for a standard and below 15 depending on chip etc...
reason i say this is cos i ran my 3.2 at santa last year in june at the GTI Festival and the lowest i got was 15.1 given that it was the first time on the strip.
i rekcon i could get around 14.9 if i really did well..
at the last northwest meet me and mark had a little run on the way home and i didnt pull away from him and he didnt pull away frrom me..and with his been chipped also..
my 2cents.
[ QUOTE ]
my 2cents.
[/ QUOTE ]
I would be inclined to go a bit lower than that, but it really depends if you're willing to risk the clutch or not.
My A3T has run a 15.29 1/4, but this was my first time, the car had only been chipped for 3 days, I held onto 2nd too long (Great 0-60 time though!) and I know there are other A3T's with faster times.
So with the above taken into consideration the S3 is a dam sight quicker off the line, and with the extra gear shift needed i would expect a standard S3 to be under 15 by a bit.
I've run a 14.61 in my chipped S3.
It was my first time on the strip (with helmet on so couldn't hear engine etc.) and it was dubbed a 'slow' day due to weather.
I was also on the border of gear change and didn't have enough runs to work out which way was best..
Also Imola S3.. I have just installed a blitz digital boost gauge and I'm peaking at 1.5 bar (22psi)under hard acceleration but that doesn't seem to hold at that. Another thing i have noticed is that it only gets up to that level in 1st/2nd. It may only boost upto 1 bar in 4th for example. Is this correct or a dodgy maf (although the car was plugged in last weekend and nothing showed up)
[ QUOTE ]
So if mine is boosting at 20psi I should get a nice low time then...
[/ QUOTE ]
I doubt it... red cars are slow! /ubbthreads/images/graemlins/smirk.gif
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
LMFAO
I have a slip from santapod somewhere when I took the car to japfest!!
Ran a 14.1 and that was with a terrible 2nd to 3rd gear change :-/
That was my best run on the day. (I was running full boost too).
I think I could have got a better time if:-
** I got the launch spot on.
** Didn't **** up the gear change.
** Wasn't tempted to go all the way to the redline, change about 5500-5700rpm ish. Instead of bouncing off the rev limiter a couple of times.
82
8K
