Avus Sportback
Hi Guys,
I'm trying to retrofit the RNS-E mk2 into my A3 Black Edition that has the following kit (originally had Concert radio)
Do I need to remove othe two AUX pins and disable in VCDS somewhere?
The unit is installed and working but I must have the coding wrong.
Original coding was -
Navigation: 0209755
Telephone: 0001222
I have changed the Navigation coding to 0209715 Is this correct?
What would I change the Telephone code to ....................?
Also in the CAN Gateway I have ticked the Navigation button, do I need to untick Radio?
VCDS report below
Many Thanks
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 62 72 77
VIN: XXXXXXXXXXXXXXXXXXXXX Mileage: 58200km/36163miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CBB) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 FD HW: 03L 906 022 BQ
Component: R4 2,0L EDC G000SG 3613
Revision: 13H01--- Serial number: AUX7Z0I1FN20AF
Coding: 0000072
Shop #: WSC 84224 681 674150
VCID: 6CD25115361B
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0106
Revision: 00H35001
Coding: 16426012092300FB681106E4902000823800
Shop #: WSC 06314 000 00000
VCID: 74E249756E2B
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BH HW: 8P0 820 043 BH
Component: KlimavollautomatH09 0100
Revision: 000905 Serial number: 8P0820043BH
Shop #: WSC 00000 000 00000
VCID: 73E04A696B25
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 N HW: 8P0 907 279 N
Component: Bordnetz-SG H54 2801
Revision: 00H54000 Serial number: 00000009361019
Coding: 118A0F81B0141380EF00000A0000000000084E0564060403642000000000
Shop #: WSC 06314 000 08192
VCID: 489ACD854223
Part No: 8P2 955 119 F
Component: Wischer AU350 H10 0040
Coding: 00056595
Shop #: WSC 06314
Address 10: Park/Steer Assist (J446) Labels: 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 F HW: 8P0 919 475
Component: PARKHILFE 4K H06 0102
Revision: 11001001 Serial number: 52340902803835
Coding: 000003
VCID: 418CD0A16119
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 J HW: 8P0 959 655 J
Component: Airbag AU1042 H06 0090
Revision: -------- Serial number: 003CA004WJZT
Coding: 303142383038303030374A55305238503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 499CC8815929
Driver's Airbag Crash Sensor:
Serial number: 3572DRB40000832932DQ
Passenger Side Airbag Crash Sensor:
Serial number: 3582DRB40000831C92CY
Driver's Rear Airbag Crash Sensor:
Serial number: 35128RB4000049835ECU
Passenger's Rear Airbag Crash Sensor:
Serial number: 35228RB400004ACD8D92
Driver's Front Airbag Crash Sensor:
Serial number: 35547RB400004AC4D2E$
Passenger's Front Airbag Crash Sensor:
Serial number: 35647RB400004AC455BW
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004042
VCID: 418CD0A16119
Part No: XXXXXXXXXXX
Component: E0221 H06 0030
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 C HW: 8P0 920 982 C
Component: KOMBIINSTR. VDO H19 0860
Revision: D0H19007 Serial number: 2241I007016167
Coding: 0004428
Shop #: WSC 00444 210 81309
VCID: 397CB84109C9
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533__Gateway H16 0210
Revision: H16 Serial number: 3400K092030662
Coding: E9A17F06400602002103
VCID: 3778BE793FDD
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 58185 km
Time Indication: 0
Date: 2011.08.25
Time: 17:40:16
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 2
Reset counter: 136
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:04:31
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H19007 Serial number: AUX7Z0I1FN20AF
VCID: 397CB84109C9
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8P0 035 193 G HW: 8P0 035 193 G
Component: RNS-E PU EU H05 0200
Revision: 0000011S Serial number: AUZBZ7KD203200
Coding: 0205715
Shop #: WSC 00141 211 17933
VCID: 346289752EAB
9 Faults Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 2
Reset counter: 136
Freeze Frame:
Mileage: 58200 km
Count: 2608
Clock: 17:09
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 5
Fault Frequency: 9
Reset counter: 96
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:45:27
Freeze Frame:
Mileage: 58200 km
Count: 2608
Clock: 17:18
00856 - Radio Antenna
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
00858 - Connection; Radio ZF Output to Antenna Amplifier
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:04:53
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01111011
Fault Priority: 5
Fault Frequency: 4
Reset counter: 191
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 191
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 5
Fault Frequency: 254
Reset counter: 136
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 96
Mileage: 58203 km
Time Indication: 0
Date: 2011.08.26
Time: 16:52:04
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0060
Coding: 0000692
VCID: 4380DAA97B05
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 233 2501
Revision: 00H15000
Shop #: WSC 02069 000 90108
VCID: 2C529115F69B
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 J
Component: KSG H11 0080
Coding: 1980200002186D0985054C9FC637
VCID: 4380DAA97B05
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000692
VCID: 4482D9B57E0B
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
VCID: FAFEE74DCC4F
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0205715
VCID: 346289752EAB
9 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 136
Freeze Frame:
Mileage: 58200 km
Count: 2608
Clock: 17:09
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 96
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:45:27
Freeze Frame:
Mileage: 58200 km
Count: 2608
Clock: 17:18
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:04:53
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 191
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 191
Freeze Frame:
Fault Priority: 5
Reset counter: 136
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 96
Mileage: 58203 km
Time Indication: 0
Date: 2011.08.26
Time: 16:52:04
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000144
Shop #: WSC 06314 000 1012544
VCID: 418CD0A16119
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000144
VCID: 428EDFAD641F
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 S HW: 8P0 862 335 S
Component: FSE_256x BT H34 0550
Revision: 00000000 Serial number: 00000005066059
Coding: 0001222
VCID: 4686C3BD4837
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 136
Mileage: 58185 km
Time Indication: 0
Date: 2011.08.25
Time: 17:49:25
End ---------------------------------------------------------------------
- MFSW
- BOSE
- BLUETOOTH + MOUNTING PLATE INSIDE ARM REST
- IPOD CONNECTION IN GLOVEBOX
Navigation: 0209755
Telephone: 0001222
VCDS report below
Many Thanks
Chassis Type: 1K0
Coding: 0000072
VCID: 6CD25115361B
Revision: 00H35001
VCID: 74E249756E2B
VCID: 73E04A696B25
VCID: 489ACD854223
Coding: 00056595
Shop #: WSC 06314
Coding: 000003
VCID: 418CD0A16119
VCID: 499CC8815929
Coding: 0004042
VCID: 418CD0A16119
1 Fault Found:
01304 - Radio
Coding: 0004428
VCID: 397CB84109C9
VCID: 3778BE793FDD
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 136
Mileage: 58185 km
Time Indication: 0
Date: 2011.08.25
Time: 17:40:16
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 136
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:04:31
VCID: 397CB84109C9
Coding: 0205715
VCID: 346289752EAB
9 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 136
Freeze Frame:
Mileage: 58200 km
Count: 2608
Clock: 17:09
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 96
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:45:27
Freeze Frame:
Mileage: 58200 km
Count: 2608
Clock: 17:18
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:04:53
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 191
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 191
Freeze Frame:
Fault Priority: 5
Reset counter: 136
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 96
Mileage: 58203 km
Time Indication: 0
Date: 2011.08.26
Time: 16:52:04
Coding: 0000692
VCID: 4380DAA97B05
Revision: 00H15000
VCID: 2C529115F69B
VCID: 4380DAA97B05
Coding: 0000692
VCID: 4482D9B57E0B
Coding: 0000013
VCID: FAFEE74DCC4F
Coding: 0205715
VCID: 346289752EAB
9 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 136
Freeze Frame:
Mileage: 58200 km
Count: 2608
Clock: 17:09
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Fault Frequency: 9
Reset counter: 96
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:45:27
Freeze Frame:
Mileage: 58200 km
Count: 2608
Clock: 17:18
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Mileage: 58191 km
Time Indication: 0
Date: 2011.08.25
Time: 19:04:53
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Freeze Frame:
Mileage: 58190 km
Count: 2508
Clock: 19:04
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 4
Reset counter: 191
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 191
Freeze Frame:
Fault Priority: 5
Reset counter: 136
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 96
Mileage: 58203 km
Time Indication: 0
Date: 2011.08.26
Time: 16:52:04
Coding: 0000144
VCID: 418CD0A16119
Coding: 0000144
VCID: 428EDFAD641F
Coding: 0001222
VCID: 4686C3BD4837
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 136
Mileage: 58185 km
Time Indication: 0
Date: 2011.08.25
Time: 17:49:25
