hi guys. got a real melter of a problem. a few wks ago i started my car, it starts on the button with one turn of the key since i bought it four yrs ago but this time it turned over about seven times before starting. so this has been happening all the time now, and now and again it starts first turn but not that often. i thought it was drawing in air somewhere so i checked all the fuel pipes and put some propper fuel hose clamps on all the pipes. i changed the one way valve on top of the fuel filter and the filter aswell. i took the lift pump out of the fuel tank and and cleaned the filter on the bottom and checked that it was working and put it back in. the fuel relay is working and im happy its not drawing air. the starter and battery are like new and it turns over very fast. i changed the injector wiring loom today and i fitted a reconditioned fuel pump on the back of the head. when you rev the engine and turn it off and then start it right away 7 times out of 10 it starts first time but when you leave it a while it wont start unless it turns over for a bit. cheers guys.
