Aftermarket HU with Bose?
DJ_Troopa
West London
Who here has Bose in their S3? When you changed the unit for an aftermarket one, did it sound better or the same as the standard Audi HU?? I've got a concert stereo so not sure if it will make any difference?
AJ
Ive got bose set up and now have an alpine DVD headunit,
The sound in my opinion is stronger and better
I don't have a bose system in my a3 but I'd assume it would sound better. With the wiring adapters you would still keep the standard sub/amp running and the speakers (rear) running through the amp so there won't be any loss of sound/power. Most decent head units give you more options to adjust the sound, ie more than just the normal equlisers would (jazz, rock, pop etc).
Most new headunits will also be 4 x 50 watts minimum nowadays too. Whats the output on the standard stereo?? If power rating is the same then there probably would be much difference but again, you will still have more flexibility of how you want it to sound in your car.
Most new headunits will also be 4 x 50 watts minimum nowadays too. Whats the output on the standard stereo?? .
this is what i was going to say, the OEM HU will have low power output so when you turn it up the quality reduces, a new HU will be 4x50wt so it will go louder and sound better,, this will highlight the fact that the speakers are naff but when both the OEM HU and an aftermark HU are compared at the same sound level the aftermarket one will sound much better
I was happy enough with the sound of mine after fitting my Alpine HU... I have since fitted a lot more kit but tbh other than more volume and better bass from the Andy Mac sub I could have just got away with fitting the the AMSS and Alpine and been happy enough...
I took out my tv hi and put the standard hu back in but I also put a 12" alpine swell as the standard Bose set up the louder if gets the better it sounds!! IMHO the concert system with the extra sub sounds loads better than after Market hu. I used to run tv + 2X12" subs and infinity mids + tweeters in my cossie and the sound was not as good as the Audi but that could be the difference in the car build quality
