The Stance Thread
Yes you do need to remove headlining, they have special fixings for these to bolt onto.
1) Picture of your car;
2) Brand of Coilover/suspension/Air Ride;
KW V3 Coilovers
3) wheel and offset;
BBS CH rims 18x8J ET45
4) tire and size;
Dunlop Sportmaxx 225/40/18
5) spacer brand/thickness;
Custom Alu spacers, Rear 13mm
6) other info (fender rolling, replacement tie rod ends, etc);
Removed rear arch screw and trimmed the inner edge!
Looks hot!:icon_thumright: What camera did you use? So much detail. Also what upload method did you use? Photobucket seems to be messing around with my picture quality
1) A3 2.0TDi Sport 140
Sport standard
BBS replicas - unsure of offset
4) tire and size;
225/40/18
None
None (that I know of!)
Just bought this so finding out about it as I go. Was planning on just adding a subtle drop, probably just 30mm springs which should give an extra 20mm drop on Sport standard I believe?
Reactions: pinterovski
1) A3 cabriolet 2.0 TFSI S Line
S Line with H&R 50mm lowering springs
OEM standard
4) tire and size;
225/40/18
Front H&R 10mm I think to accommodate Forge 330 Big Brake Kit
None
KW V3 Coilovers
OZ Ultraleggera 18x8J et45
4) tire and size;
Bridgestone Potenza re50a 225/40/18
H&R Trak+, rear 13mm
Reactions: zyzio and S.
need some ultras :D
Bilstein B16 PSS10 Coilovers
BBS CH 18x8J et50
4) tire and size;
Michelin Pilot Sport 3 225/40/18
None in the pictures. Now H&R Trak+, front 10mm, rear 15mm
Nothing yet.
ok then, here's mine :D
kw v3's
3) wheel and offset
oem facelift s3 wheels 18x7.5 et54
4) tire and size
michelin pilot exalto 225/40/18
dunlop wintersport 3d 225/40/18
scc 12mm front
nothing
thanks mate :D
that's with summer tyres. actually with winter tyres it looks the same :D
Not exactly 'stance', but hopefully will help others to know what difference just springs make..
Pic before
IMAG0402
And after
IMAG0930
Eibach Sportline
Wheel and offset
OEM 7.5 x 18 ET54
Tire and size
228*40*18 Conti Winter Contacts
Spacer brand/thickness
None (yet)
Other info (fender rolling, replacement tie rod ends, etc)
Nothing
I will also add it has taken away all the crashy ride it had before, and is MUCH nicer to drive now
Airlift V2 suspension with performance struts.
OEM Facelift wheels, Bridgestone tyres. :blink: (Just for winter).
Reactions: Jonathaan and pinterovski
Shine1
Bring this thread back
VMR V701 19x8.5" ET45 w/10mm rear and 8mm front spacers
225/35 19
BC Racing BR series coilovers with 10Kg springs
Reactions: Tay_GP, kash_v, saq85 and 1 other person
Liking that! Moaaaar pictures!!
Reactions: Compkiler and GGG_666
just found this thread, very helpful as I'm looking for new wheels
Comparison of 18s vs 19s:
Now:
Eibach Pro Kit lowering springs. Thinking about fitting Sportlines - thoughts?
3) wheel and offset
Genuine RS3 alloys (8J x 19), ET50
4) tire and size
Goodyear Eagles, 235/35/19
None. Thinking about 8mm spacers for the front soon though.
None
Wondering if I could have some ideas... I'm wanting some staggered Rotiform ind-t in in the new year ready for some shows only issue at the moment the rear option is the front: 18" 8.5j et45 rear: 18" 9.5j et35 will the rear fit? Don't mind a tad of poke but will lower as much as possible on those wheels.....
Myb takephototmp
CAR
17 " PORSCHE TWIST
8.5 J FRONT 9 J REAR
205/40/17 ALL AROUND
ET 35 i believe , running 30mm adapters all around not sure of brand
fk street pro coilovers.
17 " PORSCHE TWIST
tidy stuff! Didn't think people went for smaller wheels! Looks good though! I want to stick with 18" as the 19" I wanted were 10j so thought that it be a bit of hassle, maybe next wheel I go 19"!I need to see a pic of 18" 9.5j et 35....rear but no spacers
i only went for 17s as it was on audi s line alloys which were 17s when i got it.
its going on air early next year and smaller wheels and air go well together i think , if i go bigger i need to find some thing with an offset that will give me some nice tuck. but thanks for the feed back mate :glee:
Reactions: Welshy
ET35 will rub/scrub on the rear
Now:
3) wheel and offset
4) tire and size
None
That's crap lol!I been told it be fine, oh well!an ideas where the best place to get rotiforms would be? I prob run a bit of camber as I seen people with lass then et 35 and still fine hmm!
That's **** lol!I been told it be fine, oh well!an ideas where the best place to get rotiforms would be? I prob run a bit of camber as I seen people with lass then et 35 and still fine hmm!
you can get rotiforms from car audio security or rim style i think
Yeah I been looking on there but if I was to have staggered I think they are et35, you think if I gave them a call they would know fitment and that?
No belly-dragging here I'm afraid.....
Also I have no idea about offset,so...
kW Clubsport suspension with adjustable topmounts.
H&R ARBs
Superpro bushes and ALK
TD 1.2 alloys 18 x 9
Michelin Supersports or Toyo R888s 245x40x18
Around 2.0 degrees negative camber on the front,and 2.5 on the rear.
One dirty picture....LOL
No rolling,no rubbing and no spacers.
Reactions: kash_v, HHS3 and Welshy
no doubt you could get away with it with loads of camber but you'll run thru tyres like crazy, it always looks good but in reality it's not practicle. Are you running air or coilovers? I had ET35 and ended up chipping some paint off the wheel arch... I've since changed to a higher offset
Yeah, well to be honest I think that's the only way to manage is camber but like you said it isn't practical but again the wheel will be for show use and my neighbour works for quick fit haha! But I think I'd prefer less hassle, I think for me et35 it a bit of a push and I like my paint lol! So what offset you running as you have some pokeage?
The pic I have up is from my ET35, I'm currently ET45. I had originally put 10mm spacers on for a car show and then left them on... that's how I chipped the paint. I could see doing it at a show then removing the spacers
I see GGG 666! I would like too run them for summer and shows! Just et45 won't have any staggered fitment unless spacers grrr! Done an offset on will it fit and well seems ok but no idea on how much it will poke lol! I just want more concave on the rear... will call them Josh....
Click on the image should get half an idea lol.....
4052 This is my old set up, 19x9.5 rear ET35 and 19x8.5 ET35 front.... way too much poke
20140601 153026 Heres my new one 19x8.5 ET 45 front and rear (I also used spacers on this set up for shows)
I get what you're saying, it's difficult to find the happy medium between fit and function but I think I finally got it. You'll have to do some thinking I guess
Reactions: Welshy
See your point there! But have to say a bit of camber and those 35s would look good, but if I do go this way I have 45 front, yeah exactly my point! I can go 45 rear on the same wheels just no concave, either way once I have them I will do whatever to run them, that happy medium is a tough one as I like the perfect fitment only other way is laser cut lol! Will have to have a think for sure!
Reactions: GGG_666
View attachment 73268 This is my old set up, 19x9.5 rear ET35 and 19x8.5 ET35 front.... way too much poke
View attachment 73269 Heres my new one 19x8.5 ET 45 front and rear (I also used spacers on this set up for shows)
Are you running the spacers on the 2nd photo?
