Alloy Wheels
roba4cab
Am i right in saying that alloys with an ET 54 will fit on my 2004 cab with wheel spacers?
They'll fit yes, but you'll need a minimum of 10mm spacers for it to look half sensible.
What offset can you fit to a B6 with/without spacers??
I'm running 18" x 8.0J, with an offset of ET42, with 10mm spacers, making them ET32. Wouldn't want to go any lower - that's about the limit on a 'standard' B6.
Not sure about the S4 - maybe it has wider arches to accommodate a smaller offset.
I agree, 32-35 is the lowest ET for me, unless you like stretch/poke etc, but I'm not into all that.
S4 has the same body as A4's.
Sent from my BlackBerry 9700 using Tapatalk
Most of us are using spacer's, so don't be put off..
Thanks for the info :icon_thumright:
The reason I asked, was that I had seen a set of 16" alloys which would of been ok for winter but they had a offset of ET31 so wasn't sure if they would fit or not.
ET 31 will probably be ok, as being 16's they're probably a 7.5j width?
Hi was running 8x18 et30 and they were still under the arches .
695
861
452
859
20
