Rear coilovers adjusters H and r
rob irl tdi
Are the rear coilover adjusters suppose to be fitted on the top of the spring? I thought the car would have been low at the rear to match the front like an even drop. I was told they were wound down the whole way at rear
They fit on the top on my KW's and I can't see H&R being any different. The spring sits on the standard rubber mount on the lower arm.
It looks like you still have the standard rubber top bush fitted. My KW's don't use this and just have a large nylon washer under the adjuster platform.
Might be best to contact H&R.
KW were very helpful when I needed some advice.
BUB
Correct the Rubber bush at the top need's to be binned..
846
DPM
843
DPM
12
