So.....
I've gone and gotten a 6 speed conversion done! Thanks to Benjamin for fitting it all. That lad still amazes me with his knowledge and mechanical skill.
6 speed box
Starter motor
Clutch pipe
Power steering pipe
Gear linkage
Drive shafts
I needed the cv joints nut type.
New LUK clutch
Flywheel
Release bearing
My setup was really old,, the speedo sensor and reverse lights needed upgrading.
Thoughts... Absolutely love it! My gears struggled to go in and when it did there was so much movement there. Now it's smooth, slots into gear and feels tight. Just getting used to the extra gear now.
Since fitting the brembo i used the old discs and pads. Not a good idea as the car/steering wheel wobbles so much when braking. I have just ordered new discs and pads to solve this.
323 Mtech discs
LCR brembo pads
The 5mm spacers I had on the front is not enough to clear the calipers. So I swapped the 15s from the rear to the front. When I travel between 70-80mph there is a small wobble from the wheels. I'm hoping it's only because the spacers aren't flush. New spacers on the way to fit same time at discs to see if that eliminates the wobbly.
6 speed box
Starter motor
Clutch pipe
Power steering pipe
Gear linkage
Drive shafts
New LUK clutch
Flywheel
Release bearing
323 Mtech discs
LCR brembo pads
