Tyre size
Arrkon
Back in a "B"
Staff member
Moderator
Regional Rep
Coventry, West Midlands
What tyres would need to go on some RS4 17's to keep the same/similar rolling circumference as my 16's?
im thinking 205/45/R17? :sorry:
225/45 is standard fit on TQS and S4's, and is the same diameter as the 205/55r16 tyres fitted to the 16's from factory.
sounds good to me, speedo will be about 0.3% faster at 60mph can live with that, cheers.
Can you correct the % speed differences with in VCDS?
I've noticed on newer cars you tell the speedo if you're running winter tyres or not, so I assume this corrects the speedo for different size tyres.
You should have 205/55r16 at the moment, so you want 225/45r17 if you are going with 17's (same size as b5 S4 & 1.8tqs)
944
922
