Haldex
G60DAN
Cornwall
Hello all
Right I'm getting an error code 65535 from my haldex had a look at the plugs and there fine put a new earth strap on and still get the code. Now what I would like to know is there any coming back from this
Internal Control Module memory error or do I need a new one.
Thanks for any help
65535 - Ross-Tech Wiki
What makes you think its the Haldex? most of the info I have seen suggests the ECU and check sum errors?
What module did you scan? have you got the output of the scan from VCDS to post up?
Controller may be to blame if its coming from the AWD module...
Right got the print out
Address 22 AWD Labels 02D-900-554.1b1
Part no: 02D 900 554 B
Component Heldex LSC ECC. 0006
1 Fault Found
65535 Internal Control Module Memory Error
00-00
That fault code is associated with checksum errors... maybe water in the controller or something... you may be able to remove the controller and take it apart to clean it/dry it/resolder joints etc...
Thanks Tuffty will have a look at the weekend and pull it apart and see if it's wet in side.
10
590
616
32
3K
14
