airbag light
stuartyp
Hello my airbag light is on. when put onto the computer it say's it's the plug under the seat. My question is can i change the plug or is there an other way to turn it out and keep it off.. ie, join the wires or put a resistor across the wire's.It's dew mot next month so need to sort it. Many thanks stuart
Have you been cleaning the car. I had the airbag light come on after I had moved the seat all the way back to clean the car. Just check the plugs under the car and clear the code. If it comes back then there may be a fault along the line. As far as joining the wires, it would not be solving the problem plus it would be a ****** of a job unless you take the seat out to try to join the cables back up without the connector.
939
NHN
659
NHN
726
