large port head?
jam333
northallerton
2003 reg s3 will a large port head make much difference and how much of a job is it put change over to one of these
ie rods xs mani 3 inch down pipe too sport cat and miltex exhast cat back. b5 tip and jetex cone
The APY never came as a large port APY was small port as well as BAM
AEB and AGU are the main large port heads to look out for.
Do a search and you will find all the info needed about the swaps.
With your spec your best fitting a hybrid, manifold, 440/550cc injectors and then you'll be flying
well its just that i have just seen a APY head that has been ported and polished so would this not mean it is a large port now?
Instead of starting numerous threads asking questions that are all related to your engine build it might have been better to stick it all in one?? retains a little context then and neither you or people replying will need to repeat themselves :)
APY is small port and even a ported small port won't flow the same as a large port... porting a small port does not make it a large port... ever :)
739
13
HTC
938
13
