B7 RS4 ARB on B6 Avant
duffy78
Would this fit?
[h=1]Audi RS4 B7 rear anti roll bar 8E0511409AJ[/h]
Also what else should i be looking to replace at the same time as the arb? bushes, drop links etc or will just an arb suffice.
this is the parts list that i fitted,
8E0 511 409 AL - Stabilizer
8E0 511 327 A - bushes x2
8E0 511 439 - clips x2
the bushes were very tight to get on i had to heat in boiling water,
i also changed the rear drop links.
what an awsome upgrade.
the rollbar is for a cab so not sure, i would give the dealer a call as i recall they are cheaper than that one
This is a very good upgrade !!
same parts as above for my car too
i went from the sport 18mm to the RS4
22mm
realy good added to my B12 suspension
super
yes it will fit
Is that definitely for a cab the one listed?
Same one as listed above on my bills with AL on end
thats for 4door saloon aswell
I have just had one fitted to my cab.
Went from a 20 mm rarb ( on the S4) to a 22 mm.
Now it appears that after ordering the bar from a B7 RS4 cab, when I measured it and then measured what I had on my car it was no different and still only 20 mm.
So basically, what I found out at the dealers was that the B7 RS4 cab has a 20 mm rarb and if you want to upgrade to the 22 mm rarb you have to order the bar from the B7 RS4 saloon.
As already said but to confirm the rarb you require ( if you want 22mm ) is from a B7 RS4 Saloon, not from a B7 RS4 cab and is 8E0511409AL
I also ordered 8A0511439 clip and 8E0511327A mounting bush but was told by the indie who was due to carry out the work that these would not fit. Now, these may well fit but on their Etka system it gave a diff number and they didnt try to see if it would fit.
So they ordered the parts they thought they needed and I didnt see what numbers they were but I still have the mounting bushes 8E0511327A and clips 8A0511439 that they didnt use, still in the Audi bags if someone wants them. Send pm pls.
Have just re read the thread and the OP duffy has asked if 8E0511409AJ would fit, well that is the part I originally ordered but when I picked it up from my local Audi centre it was only 20mm and therefore no different to the one already fitted to my S4 cab and so I took it back to find a 22 mm one. As I said above if you want a 22 mm rarb you need part number 8E0511409AL Stabilizer Bar.
Hope this helps and good luck
What about part references for drop links?
8E0511409AL How much are these now its a mod i plan to bo in the next 2 weeks
I bought my two drop links separately off ebay, I think they were roughly £12 each.
Fourcircle did a how to guide for this I think?
