Well done to yourself and Badger Bill.
Welcome to the 600+ club.
Thanks Alex! It's still sinking in, can't wait to drive the thing!!
What were you thinking of?...only printable suggestions please.
If it relates to the bhp,that's the daily setting....the final set of horses is in the 2.1 bar paddock!
Storm and Syvecs got somewhere into the low 600s at 2.1bar,without fiddling with the VVT or ignition timing,and then wound it back a bit for the sake of the gearbox,and also the exhaust aft of the downpipe needs a little bit of work at those flow rates.
Gops whats the spec?
Half the time I need it turned downThis isn't the 'occasionally' 600+ club you know!!
I'm in the 600+ 'once my boost is turned up (hopefully)' club...
The older I get the faster I was etc
Only when you have enough power to warrant it!! LOL
I love goooooollllld!!! Lol! I get to drive it next week on Monday when I'm back from holiday!
copper pipe for the main front to rearOne more silicone hose to worry about
You'll be back!Was in the 600 club for a very short time but killed the box big time
I'm still crossing my fingers....
540lbs and it hasn't broken.....yet.
You know I'll be "granny shifting, not double clutching like you should"
Hehe
You'll be back!
How's she sounding inside? I'm guessing the nice and quiet?
Hehe
none of that enabled.NLS or go home
no pops or bangs allowed - because I said so!
ADI ?
your still not having itYeahhhh I've been told I'm not allowed it turns out samosa's didnt do the trick huh! The thing with ALS or NLS is that it will kill my turbo. Costly for a rebuild! Would be nice to use on the yearly drag strip though?
I predict a crash if gops trys to keep up with you in itAs above, fancy a race
Now, @badger5 and @<tuffty/> will have to rip the block apart to replace the piston rings you fried...You know I'll be "granny shifting, not double clutching like you should"
Hehe
/End of
and the reason is I see the aftermath of folks using it.
Destruction
I dont need to see it or deal with it so you dont get it on "my build"
the handling does not match the performance imho
So @Gops , when are you dropping off my haldex controller in my old S3?
