Farhan
Hi all,
I have recently ordered some hubcentric spacers,
10mm Fronts
13mm Rears
I now need to order longer bolts and i am aware the stock wheel bolt length is circa 28mm, Now logic tells me yes i will need bolts 10mm and 13mm longer.
However, Searching online the common sizes are 40mm & 45mm, I can buy a set of 20 which work out cheaper but if i fitted 45mm length bolts on the 10mm spacer i would have an extra 5mm? Would this cause a problem? I worry they may tighten up to far into the hub and be to long.
Aslo would 40mm bolts be ok for the 13mm spacer as there would only be a shortfall of 1mm?!
10mm Fronts
13mm Rears
