Syncronising remotes A6 C5 help
wesmaster
Oxfordshire
Hi, on a friends A6 allroad, both remotes have stopped working, I have had this on my A6, I found an online instruction which involved pressing the lock or unlock buttons 1 time for remote 1 and 2 times for remote 2. I cant find these again. can any one help?
Much appriciated.
Wes
Found this .... Not sure this works on Immob' III vehicles...
Programming new remote controls
Two keys and all the remote controls that are to be programmed
will be needed. The maximum number of remote controls that can be
programmed, including old and new, is four.
- Insert first key into ignition switch, and turn it to
"ignition on."
- Insert second key into outer door handle, and turn it to
unlocked position for 10 seconds.
System alarm will emit three beeps.
- Take first remote control to be programmed and press button
-1-, two beeps will be emitted. For second remote control, press
button -1-, two beeps will be emitted. Use same procedure to program
third or fourth remote control. All remote controls must be programmed
within one minute, otherwise new programming will cancel and old
remote control programming will be valid.
- Turn key in outer door handle to unlocked position for 10
seconds, one beep will be emitted.
- Switch ignition off
P
877
Pedrödelabongo
P
Rza
