Hi all,
I know there is a lot on this forum already about this very problem but I have spent hours researching and troubleshooting and really want to know the most likely problem . Car is a 2000 reg Audi A3 8L 1.6 Standard Trim .
So basically it all started when I realised my car wasn't beeping after I locked it . About a month ago, I used vag-com to code in the car to beep when i locked it as i thought this was pretty cool. But just about a week ago it stopped beeping upon locking. A few nights later after this started, I realised at night the alarm would go off sporadically, even if I didn't lock the car. It has got to the stage now where the neighbours have complained to us. Today, I took the boot trim off the back and looked to see if the microswitch was wet as i hear this can be the problem. In addition , the rear washer doesn't work, but i beleive that it's now the joint under the subwoofer or around that location as the front and rear joints are fine. The micro-switch wasn't wet.
The alarm goes off in the day and night, but the indicators don't flash. To be sure it wasn't the microswitch, I unplugged it completeley to be safe. Nothing happened until around 10 minutes ago ( 12.30 am ) , the alarm just went off again ( car unlocked ) and I had to de-arm it.
I am now led to beleive that it is the siren or something causing the issue?
Can someone confirm that it is most likley this, and how I go about fixing (quick if possible).
In addition will disconnecting the battery stop the siren going off or is there a blade fuse i can pull out ?
Thanks in advance and sorry for the essay!
Jack
Jack
