really it depends on the sensor as some MAP sensors will not read a -ve value and as such can be mounted in teh inlet manifold without any issues. Most jap stuff tends to have the MAP sensor mounted in the inlet manifold.
this is a 1.8t..
it reads both vac and pressure... me7 cant make sense of vac however so it must be non vac located, ideally as vag designed it, before throttle, after intercooler
Thanks for the replies guys, going to fit a FMIC and want to change all the piping. Have to get a FMIC locally as its too costly to ship one over.
That forge pipe looks interesting, thanks Tuffy, might ship one of those over
