02071 - Local Databus Fault Code
paul_cosma
Thursday,14,June,2012,21:50:27:10074
VCDS Version: Beta 11.2.0
Address 09: Cent. Elect. Labels: NONE
Control Module Part Number: HW: 8P0 907 279 D*
Component and/or Version:
Software Coding:
Work Shop Code:
VCID: 55A5856787C1
Fault Codes have been Erased
1 Fault Found:
004 - No Signal/Communication
I cleared this error but always appeared again.
I have Audi A3 2004 , 2.0 FSI 110kwh AXW
The emergency light button stays on always. After 30minutes the computer is trying to close it but the red light apears again.
The problem is that my battery runs out of power after 48hours.
I put a new battery but the problem has not disappeared.
I have changed the comfort computer, still have that problem.
I removed the light switch but still have that problem.
What i have modified om my car :
- aftermarket xenon.
- interior lights with LEDs
- number plate lights with LEDs
I have not seen any connection between these lights and the problem i have.
Sometimes the problem go away by itself and weeks later see again that indicator (emergency light button) that stay on and the battery is consumed.
I had this problem last spring, did not fix it, dissapeared by itself and now it appeared again, dissapeared for a few days and now it stays on and even if my battery is fully charged it fully goes of after 72 hours. the battery is new.
I checked all cables from the computer in the trunk (right side) and everything is fine.
What should i do, change, disconnect to identify the part that creates that problem ?
Thanx and sorry for my english :D
changed the hazard switch, still have that error, the new hazard light always stays on to inform me that the battery is used.
You're using a fake, clone, illegal cable so I cant help you anymore.
22K
K96
4K
3K
53K
