Air con problems. update/ hdcs
ant28
so i have no cold air coming out of air con. had it regassed still no cold air, downloaded vcds lite scanned the hvac module ( which i think is for the air con / climate control ) comes up no faults. dont know what else to do HELP PLEASE. cant afford to take it to dealers, have three very expensive daughters.
Do you have air coming through at all....just not cold?.....Did you have your condensor checked out...is that ok?
A
Alternatively your compressor is shot. Not sure if that would come up with vcds errors but it's an expensive part unless you can get one from a scrappy. Thing is, you'll need to get it regassed if it is the compressor.
is the econ light on the climate controls lit up and will not switch off when pressed if so its the sensor mounted on the side of the aircon radiator behind the front bumper, had this on my 2003 a4 cabriolet ,cost around £35 quid from audi if i remember correctly and is just unscrew old and screw in new unit .
cheers dav
455
817
NHN
