G
_G_
Guest
I've been trying to figure this out for a while now... mine has an additional hose connected to it which is covered in oil... I traced this hose across the engine (underside of the high pressure fuel rail, attached with plastic ties)... down the cam shaft side side... and to the bottom of the driver side bulk head... that's as far as I've got...
This valve type thingy that is connected to the manifold is fed by the pcv... so I'm guessing it is all pcv related... as these engines have excess crankcase pressures and not the best escape routes...
It loos like an OEM part... anyhow... 2.0 TFSI (BWA)
I screwed the hose back on tight... but oil is still finding its way out through the threading and the plastic tie securing the hose to this valve is useless.
