Rs4 Alloys
Coless3
Will genuine Audi rs4 alloy wheels fit straight onto my s3 8l.
Will these alloys fit without Rubbing on anything because the width on the avus are 6J and rs4 are 8J
I have noticed that the pcd for the rs4 ones are 5x112 and the standard avus are 5x110 will I need adapters?
Also noticed that the offset is 48 on the rs4 and the offset on Avus is 35 will this make a huge difference to the car or effect handling etc? :)
They wont fit if they are 5x112, the S3 8L are 5x100 for info.
If you do want them to fit, you will need adaptors.
I think the 5x100 ones that you need are the TT RS ones....have a look on Ebay they do come up from time to time.
just so you know, standard s3 wheels are 17 x 7.5j, 5 x 100, et32
gen rs4 alloys wont fit without adapters like nilz said.
if its the early rs4 wheels you want, then ttrs wheels are very similar, or failing that replica rs4 wheels that tend to be multi-fit (5x112 and 5x100)
Even if it is the genuine b5 ones you want they're 8.5j et20 so even if you get the thinnest adapters h&r do you'll end up at et5 which, unless you run stretched tyres, isn't going to work.
The ones your looking at are not genuine rs4 wheels.
620
921
13
3K
797
894
