I've got an SE front ! Question is . Does the s4 lower grill fit ? Also I assume the upper grill is a straight swap !! Is it worth just getting the inserts without the surrounds !! Cheers in advance
The S4 grille is much deeper than the standard grille aperture, you can either cut the lower to fit the grille, I have some pics somewhere if you've never seen any. There's a great thread on it on Audizine.
Or, cut the S4 inner to fit your standard outer like I did:
