Over the weekend I have managed to successfully remove my entire sub frame, along with the appropriate cables/wires etc. to gain easy access to my transmission so that I can replace my clutch and flywheel. Both front drive shafts have been removed, along with the annoying 6mm hex bolt inside the flange shaft on the driver side, propshaft is connected to the bevel box â which Iâm not intending to remove.
I will be using an engine support beam and what I would like to know, is it possible to only undo the gearbox mounts, and slightly lower the engine while the engine mount is still connected?
