Can the forge blow off valve affect boost loss when fitted
S sewell10 Registered User Joined Dec 19, 2010 Messages 233 Reaction score 12 Points 18 Location NULL Sep 6, 2012 #1 Can the forge blow off valve affect boost loss when fitted
hades- Well-Known Member VCDS Map User Joined Jul 8, 2008 Messages 9,420 Reaction score 628 Points 113 Sep 6, 2012 #2 what forge have you got fitted ? the spacer or this 1 AUDI S3 2.0 TURBO FSIT FORGE VACUUM OPERATED DUMP VALVE | eBay
S sewell10 Registered User Joined Dec 19, 2010 Messages 233 Reaction score 12 Points 18 Location NULL Sep 6, 2012 #3 I have the spacer one
hades- Well-Known Member VCDS Map User Joined Jul 8, 2008 Messages 9,420 Reaction score 628 Points 113 Sep 6, 2012 #4 you shouldnt have a problem but your dv may be ripped
S sewell10 Registered User Joined Dec 19, 2010 Messages 233 Reaction score 12 Points 18 Location NULL Sep 9, 2012 #5 Will have a look what if it has the d diverter valve bez possible turbo fault
hades- Well-Known Member VCDS Map User Joined Jul 8, 2008 Messages 9,420 Reaction score 628 Points 113 Sep 10, 2012 #6 how many miles on the car ? those turbos are normaly good are you mapped etc could be a split pipe.
S sewell10 Registered User Joined Dec 19, 2010 Messages 233 Reaction score 12 Points 18 Location NULL Sep 10, 2012 #7 Only 45000 miles car is surposed to be mapped holds back around 4000 rpm
hades- Well-Known Member VCDS Map User Joined Jul 8, 2008 Messages 9,420 Reaction score 628 Points 113 Sep 10, 2012 #8 id be looking at the DV and leaks have you had it scanned yet ?
hades- Well-Known Member VCDS Map User Joined Jul 8, 2008 Messages 9,420 Reaction score 628 Points 113 Sep 10, 2012 #9 sewell10 said: Only 45000 miles car is surposed to be mapped holds back around 4000 rpm Click to expand... hmm it could be a bad map any reciptes for the map ?
S sewell10 Registered User Joined Dec 19, 2010 Messages 233 Reaction score 12 Points 18 Location NULL Sep 11, 2012 #10 Going to order a new valve and see what goes on the car has invoice but it came with the car
S sewell10 Registered User Joined Dec 19, 2010 Messages 233 Reaction score 12 Points 18 Location NULL Sep 11, 2012 #11 Who are the best people to go to . To get a top result
