Front wishbones
Tony gold
Isle of wight
Could anyone tell me where I could get a cheap set of front wishbones from also need to tighten up the front a bit but not to much, what bushes should I get
I just bought some of eBay for £40-45 that was wishbones ball joints and drop links all for that price delivered
paint the old ones if they look worse for wear and get powerflex bushes ??
In which case they will cost more (quite a bit more new IIRC) as they are cast ones... as said, paint um unless they look like they are about to turn to dust and get new bushes... poly's for the front bush in the arm and OEM TT solid rubber ones for the rear bush in the arm...
i am sure a mew set is around £300 - so just powder coat and re-bush
Thanks for the info will Rebush, what bush do I need for the front inner on the wishbone
Dog bone mount, I have the red one and there is a yellow one, I felt a bit more positive gear changing once fitted, a lot of the other guys one here would be able to help out more than me
20
676
21
I
