In that case then you may well have an air leak... have you checked all pipes, hoses etc for signs of splitting etc? all the pipes under the inlet (normally covered in fresh looking oil being a give away that there is a leak/split pipe somewhere)... a cursory look isn't enough... the pipes split on seams, corners and underneath where you can't see them... you will have to spend some time looking but generally if it can see oil and boost then it stands a chance of splitting..
Get the car to a garage that has a smoke test machine if you are not sure what you are looking for... we use it on most 1.8t's these days and almost always shows a damaged pipe somewhere...
