Wind noise
Chriscooke
Clueless!
Taunton
Website
www.sxoc.com
I have an annoying problem with wind noise coming in from around the drivers door at sny speeds over 50mph.
Are the door seals sold separately or does anyone know of any tricks to stop the air getting in?
try adjusting the door frame in slightly.Remove the door car and the 4 torx bolts are then visible,2 front and 2 rear.Loosen them off,push the frame towards the car slightly,then tighten up.
hth
tony
Door frame? Is the door in two parts then with the window surround being separate? Will have a look at this when I get some time. Is the card easy to remove?
Sorry about all the questions and thanks for the advice.
The window and frame (including window mech) are seperate from the lower part.Door card is 2 small screws top front and rear,1 screw by the door handle,then pull that part of trim down to reveal another 2 screws,then pull the doorcard upwards.
hth
tony
947
10
