fitting rca leads to a standerd audi head unit ?
harvey01
hi there i wont to keep the standerd look but need a minium of 1 set of rca leads can it be done or amd i better of getting a cheap head unit with red front
Depends on the model/age of HU. All Audi HU's have front & rear pre-outs, they are just not on standard RCA connectors. Some are on mini ISO and later models are on Quadlock. Easiest method is to tap the rear pre-outs at the rear amp or sub depending on what you are going to be using them for.
The BLAU adapter (PC3-11) provides front and rear RCA's for ISO HU's (all Audi single DIN HU's are ISO as well as pre-2005/6 double DIN). However you have to unplug the existing feed to the rear amp (or Bose amp if you have Bose) in order to connect it.
Mini ISO Yellow 6 pin pre-outs to RCA Sockets online at Nexxia UK
So depends what you are doing as to the best method.
